Home > Maintenance & Mods (L322) > injector issue help please
Darryl72
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi folks,
Whilst coming home from a couple of hours away my RR started to miss fire, pulled over in the nearest services and found that by putting a little pressure on the injector harness just above the 2 injector she went back to smooth with no issues cable tied it down a drove home normally,. Thought it was the harness so I ordered another from the bay second hand, ,Ive now fitted it with the same issues, same place and same cure as above.
I think chances of two harnesses being broken in exactly the same place a long shot so now Im thinking the injector, anyone else had this sort of issue and resolved it? hopping its just a clean up at home jobbie.
Thanks in advance!
Post #532741 31st Oct 2019 12:13pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
I've had to change 2 injectors at different times for the same reason. The first one just pulled out but the second was a nightmare ! Being an engineer I have a vast collection of tools at my disposal in my garage and only succeeded in destroying the top of the injector. I bit the bullet and purchased a dedicated BMW diesel injector remover - what a god send ! Came out a doddle. The issue is the carbon build up around the base of the injectors , tried the soaking in cola trick etc but still wouldn't shift. Just ensure you use new copper sealing washers when you refit or fit an injector Smile
Post #532755 31st Oct 2019 1:55pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I would take some time to clean the terminals on the injectors and carefully try and close the terminals on the loom plugs to ensure a good connection. Once you are sure its not the loom then a replacement Injector seems probable. They are quite easy to change if the old one wants to come out. Get some Plus Gas or similar into the injector hole ASAP then plan for the job. I use a cheap ebay puller, it fits onto the Fuel inlet thread, You need to tap sideways back and forth whilst wacking the slide hammer up and down. No need for brute force just constant repetition should get it moving slowly upward and out
https://www.fullfatrr.com/forum/topic50900...6+injector 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #533025 3rd Nov 2019 12:24pm
wayneg
if you do need an injector, keep an eye on these, they could be a bargain https://www.ebay.co.uk/itm/3-x-Diesel-Inje...Swxs1dvdOj 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #533047 3rd Nov 2019 3:11pm
Darryl72
Thanks folks for the information,I'm going to try cleaning the terminals and just test to see how the injector comes out while I'm there just in case!
Watching them wayneg!
Post #533069 3rd Nov 2019 8:10pm
