Home > In Car Electronics (L405) > Rear Dash Cam |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
maybe a different location on the rear window might help.. |
7th Jun 2019 8:53pm |
SCL Member Since: 10 Jul 2017 Location: West Midlands Posts: 50 |
Thanks Chalky, saves me a job tomorrow.
7th Jun 2019 9:25pm |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 891 |
Here's my installation by Dash Witness as well. Very neat job....Can someone PLEASE tell me how/why all my uploads of photos are either upside down or on their side??????????????????
8th Jun 2019 11:12am |
pmanchuk Member Since: 04 Nov 2019 Location: Miami Posts: 1 |
Similar to SCL, I have a blackvue (which I transferred over from my previous RRSport) and did the install myself - the rear cam was actually easier and cleaner than the Sport simply because on the full size, the interior panel on the tailgate is accessible (held by clips) rather than the full one piece moulded panel in the Sport... I ran the wire front to back tucked up in the headliner, then through the rubber conduit to the top of the tailgate, down the side (behind the removable trim next to the support strut), through that same grommet which puts the cable back into the interior (effectively behind the license plate). The small difference in my install was that I popped out the rear sun load sensor, pulled the cable through there and was able to re-seat the sensor without having to enlarge or make any additional holes. As SCL mentioned, because of the angle of that interior trim, the cam is pretty much invisible when looking in the rearview mirror which makes a world of difference to me (on the Sport, I had mounted it at the top of the window and always noticed it in the mirror). Overall I'm quite happy with the outcome of the install particularly being a DIY job and it's all rather stealth (tinted glass helps) unless you're really looking for it.
4th Nov 2019 4:01pm |
nice work ... - .- -.
4th Nov 2019 8:05pm |
basil Member Since: 09 Dec 2014 Location: UK Posts: 88 |
I had the same DAB issue after my twin camera BlackVue dashcam was fitted - but the auto sparks sorted it by moving the cable away from the DAB cable - DAB reception is now almost perfect. |
4th Nov 2019 11:20pm |
dazsear Member Since: 23 Jan 2011 Location: Lincolnshire Posts: 65 |
Well I’ve been fitting my BlackVue twin camera yesterday and the rear cam is certainly a challenge to do properly.
13th Apr 2020 9:10am |
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 |
It’s entirely your business, but my Power Magic is in the front passenger footwell fuse compartment, behind the glovebox unit. (Squeeze two pegs and it drops down).
13th Apr 2020 9:36am |
Well it’s now all fitted and working fine with the ignition on.
14th Apr 2020 6:05pm |
I had to switch my Power Magic off 'cos with parking mode on for the Blackvue front and back cams I kept getting a low battery warning. LR replaced the battery twice thinking it was the car but it's a known fault with Blackvue.
14th Apr 2020 6:54pm |
Thanks for the advice. I’ll get the battery checked to be on the safe side while it’s still under warranty.
14th Apr 2020 8:34pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 769 |
Am I correct in assuming that the DAB aerial is located near to/underneath the exterior aerial on the rear part of the roof?
23rd May 2020 4:59pm |
