Home > Wheels & Tyres > Winter Tyres - What size wheel?
awclymm
Hi Folks
I'm pleased to be back in the fold - I had a string of Range Rovers over the last 20 years or so, and foolishly when I siold my 4.4 Westminster a couple of year ago I opted for a change and bought a 5 series Touring. Lovely car but not in the same league as a FFRR... Very Happy
So, I've just sold the BMW and have found a lovely MY2017 L405 4.4 TDV8 Autobiography that I will be taking delivery of very soon.
The car is fitted with 22" Turbine Alloys, which look great but aren't going to be much use in snow and ice, so I am planning to buy a set of wheels with winter tyres.
My question is - What is the optimum rim size for winter tyres? I am assuming they work better on 19 / 20 " rims?
(Also, will the different rim size affect the speedo / mileometer readings?)
Cheers
Andy 2017 4.4 SDV8 Autobiography
Post #533211 5th Nov 2019 10:38am
Im not sure why you think 22’s will be poor in winter.
Sidewall height makes no difference other than allowing you to run smaller rims - which you are less likely to kerb if you get things a bit wrong.
There’s an argument that a narrower tyre cuts through the snow better, but I really can’t see 255 vs 275 making that big a difference
I’ve run winter 22’s for a few years now and for the last 2 winters have lived in a ski resort with weekly airport trips - so far, I haven’t had to fit my chains.
It’s ice and cold wet tarmac that make the biggest difference, most 4x4 tyres are ok in fresh snow.
https://www.fullfatrr.com/forum/topic34831.html
https://www.fullfatrr.com/forum/topic40272.html
As long as you stick yo the OE tyre sizes, the rolling radius is the same, so no changes required
Post #533216 5th Nov 2019 12:33pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
Just went through the same thing... I didn't want to run the 22" turbines for lack of tire options, ruining them, little narrower tire and I like a bigger side wall in the snow for protection/ride quality. I went with 20" 502 style wheels. I fit blizzak 255/55/20. If you have the 6 piston brakes these wheels will work.
Post #533219 5th Nov 2019 12:45pm
DrRob
I have Cooper WeatherMasters. Great tyres for the price. Shop around. Tyreleader are a good site Thumbs Up
255 50 20 on standard L322 rims 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #533223 5th Nov 2019 1:45pm
The Coopers seem well priced
https://www.fullfatrr.com/forum/topic44778.html
Post #533225 5th Nov 2019 1:50pm
