Home > Maintenance & Mods (L322) > Caravan wiring
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
Caravan wiring
My caravan has 2 plugs obviously Black for lights indicators etc and a grey one, I only have 1 socket on the car for the Black one, my question is what would be needed to utilise the ancillary grey one? Would it need a auto electrician to wire in?
Post #533591 9th Nov 2019 7:39am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
is it one of these
https://www.ebay.com.au/sch/i.html?_from=R...p;_sacat=0
if it is its power to the van
if your towing vehicle is 12v, then its 12v
it needs a wire from the batter through a fuse and an earth wire
hope this helps RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #533597 9th Nov 2019 8:41am
Fox889
The grey one is normally to power the fridge while on the move & also to run a live charging wire to the 12v system on the caravan. You would need a couple of live wires from a reliable source & an earth. It is 'do-able' but............
Personally, I would have the car converted to a new type 13 pin socket then run an adaptor, in years to come if you upgrade your caravan that has a 13 pin plug you're already sorted. Decent auto-electrician should do that blindfold.
https://www.westerntowing.co.uk/blog/caravan-12s-wiring-diagram/
https://www.ebay.co.uk/itm/MAYPOLE-CARAVAN...Sw32lYnDPb 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #533599 9th Nov 2019 9:25am
Balloonengineer
If you convert a 7 pin plug to a 13 pin plug, it becomes a MOT testable item I believe, whereas a 7 pin isn't
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #533602 9th Nov 2019 9:56am
Fox889
I'd heard that towbars were part of the test but I hadn't heard of the electrics.
Found this on the DVLA website, no mention of electrics.
https://www.gov.uk/guidance/mot-inspection...ttachments 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #533603 9th Nov 2019 10:01am
Brian Considine
Personally, I would buy a "vehicle specific" electric kit which may very well be plug and play.
Rather than faff around with adaptors get a 2 x 7-pin socket kit.
Many people find them OK but I've always had issues with the 13-pin units.
& to confirm - the 13-pin are an MOT testable item whereas the 7-pin are not (unless they are hanging loose for example). 2003 Range Rover Vogue TD6
Post #533604 9th Nov 2019 10:40am
Balloonengineer
Just done a google search and...…
Caravan and trailer electrical socket test
The change which may have the biggest effect on campers and caravanners is the new tests for towbar electrical sockets.
There will be a basic security/damage check of 7-pin sockets, but
13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in failure.
So a 7 pin socket that doesn't work properly is OK as long as its not structurally broken, but a 13 pin socket must electrically work properly on all the pins and is tested. You can buy a 13 pin MOT approved socket tester quite easily on line.
Best wishes
Post #533605 9th Nov 2019 10:43am
steve1
Many thanks for your advice
Post #533699 10th Nov 2019 11:50am
darrenm
I just use an adaptor works perfectly
Post #533719 10th Nov 2019 5:18pm
