![]() | Home > Technical (L322) > Intermittent heavy steering |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
Tyre pressures will have an influence on the steering effort, but you've got to be very low to have a big impact.
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
Inflated the tyres to 36 psi all round on Saturday which seemed to help free up the steering a bit more.
People have previously reported Servotronic valves sticking & it's easy to imagine eg small debris particles causing is to stick & hold while either opening or closing to add or remove the additional assistance the valve provides.
A quick update to my moaning..
Finally, some positive news at last!
Aagh - should hsve seen this post first!
Well, fixing one problem has led to another.
Seems I shouldn't have joked about the fix lasting more than 1 day..
That's bad news .
I didn't have a pressure test done no as I decided it was likely to be a similar cost to just grabbing a pump and replacing it.
I would have expected the second hand pump to be Ok if the stated milage was correct & you've said it was performing OK for at least 1 day - so it's hard to imagine the pump could have deteriorated that fast.
I think that could be worth a try Pawl, I might see if I can bodge something together tomorrow with spade connectors just for a quick test.
You might find it challenging with spade connectors - the pins are really small & easily damaged (maybe 2mm wide).
Hmm, sounds like spade connectors are unlikely to work then. I will source a connector to try this out.
| All times are GMT |
