Home > Maintenance & Mods (L322) > Handbrake cable bolt
Danwilderspin
Just looking into my dreaded electronic handbrake cable yesterday and notice the bolt at the back holding it in (near side rear) is missing which probably has helped is failure.
Does anyone know what kind of bolt is it’s? M6? And roughly how long as I went to take the other side out but it’s very tight and don’t want to snap it!
Cheers! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534692 18th Nov 2019 3:39pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Are you talking about the EPB cable to brake backing plate screw?
Torx about 1cm thread length and not likely to snap as hard steel into mild steel through ally' alloy cable head.
Car I'm on is 2006/2010 L322.
Biggest concern would be snapping the seized EPB cable fix plate off when prizing away from the brake baking plate. (I did just that).
Post a pic of your worry, I'm not sure we are on the same EPB end.
Best Rich
Post #534737 18th Nov 2019 8:54pm
No EPB on an '02 .
Post #534738 18th Nov 2019 8:55pm
Danwilderspin
On about my 07 Laughing
yes that is snapped too i think - its a plate at the wheel end of the cable the the bolt goes through right? there is a decent chunk of metal left so going to make a small plate to hold it in i think...
cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534762 18th Nov 2019 10:19pm
nice first post edit Thumbs Up
best to signpost which car with your profile set as an 02 Smile .
Post #534776 18th Nov 2019 11:19pm
RichM63
Moulded end of the outer cable that allows the cable to be attached to the brake backing plate and also prevents the whole cable from being pulled through when applying the EPB. The screw/bolt does go through it in about the 9 o'clock position.
Post #534794 19th Nov 2019 8:54am
Danwilderspin
Ok great - anyone know about the bolt is it an m6? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534944 20th Nov 2019 9:23pm
RichM63
M6 10mm Torx
See this diagram. Part; HS1
https://allbrit.de/epc.cfm?PAGE=2060505C&a...CHE=EN#HS1
Post #534991 21st Nov 2019 8:57am
Danwilderspin
thank you Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #535414 25th Nov 2019 4:37pm
