Home > Technical (L405) > SDV8 Gearbox issue (LR approved warranty declined claim)
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Why are these gearboxes so problematic ?
Post #511070 5th Apr 2019 9:08pm
Bessy645
I'm wondering if I have a similar issue mentioned in this thread. When I pull away turning left or right but more noticeably left its as though the car is using traction control on the rear wheels. The car has covered 49,000 miles. Full LR service from new and is currently under the landrover extended warranty scheme.
Hope for suggestions and possible costs before i book it into the dealer
Post #511580 10th Apr 2019 4:54pm
cadoganpier
United Kingdom 2018 Range Rover Autobiography SDV8 Loire Blue
I have the same symptom when pulling out of left turns, a mild thump/clonk from the back of the car, like a sort of drive shaft clonk. Not always and not overly worrying but it's there never the less.
Post #534879 20th Nov 2019 11:13am
DrRob
Lots of places now can do a Megaflush Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #534887 20th Nov 2019 1:08pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I’m not sure that they are that problematic, it’s just that (like any car forum) this is a point for those that have had problems to gather.
Post #534918 20th Nov 2019 7:53pm
Red Merle
That’s a very large leap of logic. We don’t know nearly enough about what the problem is, or how helpful the dealer is being. We could just as easily say that it’s proof that, whenever two or more LR owners gather, they like nothing more than having a good grumble Wink
Post #534935 20th Nov 2019 8:49pm
GraemeS
Any non-franchised LR workshop will be able to change the transfer case oil then initiate the transfer case clutch re-calibration.
Post #534972 20th Nov 2019 11:29pm
GGDR
Can the IIDTool do this re-calibration?
. Cheers, Greg
Post #534995 21st Nov 2019 9:29am
GraemeS
Its a diagnostic tool function but I can't recall if the IIDTool has been programmed to do it for the L322 (pretty sure its available) and don't know for the L405. I'm reminded of my request to Gap to add it to the D4 menu as it was already provided for D3s. Also like the rear diff re-calibration which wasn't on the L322 menu but I would need if I retro-fitted an e-diff, which I subsequently did.
Post #535057 21st Nov 2019 8:50pm
