Home > Maintenance & Mods (L322) > IID tool flattened my battery |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
After uploading some new settings last night, I turned off the car and locked it, forgetting to unplug the IID tool.
20th Nov 2019 7:58pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
IID manual states an external power source should be connected when CCF editing etc.
20th Nov 2019 8:26pm |
I didn’t know this.
20th Nov 2019 8:37pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
CCF editing / module programming draws a lot of current and you should have a stable, external supply connected. Another option is to connect to another running vehicle via jump leads. I'm not sure that's recommended though...
20th Nov 2019 10:17pm |
Ent Member Since: 20 Oct 2014 Location: Preston Posts: 42 |
Learnt this pretty early on the D4, the problem isn’t how much the IID tool draws its the fact your car doesn’t go to sleep that’s the issue. |
20th Nov 2019 10:21pm |
Download manual on IID website. It's not the easiest to negotiate but give it some time 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
21st Nov 2019 8:28am |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 304 |
The IIDTool draws charge when the ignition is off.
22nd Nov 2019 11:26pm |
I had to get the RAC out to start the car. It was on 7 volts when he connected his jump leads. It took his boost pack and his van to get it started.
23rd Nov 2019 2:05pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Andy,
23rd Nov 2019 6:08pm |
Page 56 of the manual might help? Pretty sure Pat at GAP will advise the same.
23rd Nov 2019 8:56pm |
I don’t leave it permanently connected. This was accidental. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
23rd Nov 2019 9:04pm |
