Home > Off Topic > GU10 Compact Flourescent lamp
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Help/advice needed please.
We have four of these lights in the ceiling of our loft, which we lined and insulated to create a home office about 12 years ago. One has just failed and my local trusted electrical shop doesn’t sell them and they suggested Screwfix. Screwfix sell GU10 fittings, but only as LEDs.
My simple question is, can I plug an LED straight in or does it need a new ceiling fitting?
Thanks
Andy
Post #535291 24th Nov 2019 9:42am
p38arover
Australia
My bathroom ceiling fan/light came with GU10 CFLs. I replaced them with GU10 LEDs a couple of years back. They plugged straight in.
How is the lamp retained in the fitting? In mine, the lamps were fitted from the rear and retained by a couple of coil springs stretched across the back of the lamp Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #535293 24th Nov 2019 9:50am
It's 240v so any GU10 bulb should work - LED or ortherwise.
It is a long unit though - standard GU10's are a good bit shorter if that matters ?
They are cheap enough these days so I'd be inclined to replace all 4 together.
Post #535297 24th Nov 2019 10:19am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
If there's no transformer to them. then they are 240v it's a straight swap as Alistair says including LEDs. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #535298 24th Nov 2019 10:25am
Andy S
Thanks all, that’s very helpful. Off to Screwfix I go!
Post #535301 24th Nov 2019 10:57am
p38arover
Australia
Yes, mine mount from the rear with a floating GU10 socket so length wasn't an issue. If the socket is fixed to the lighting fixture, then it may be a problem. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #535318 24th Nov 2019 12:44pm
Andy S
All sorted. New bulbs slotted straight in and are retained in the same fixing bracket. 5 bulbs cost £8.99, so cheaper than I was expecting.
Post #535324 24th Nov 2019 2:39pm
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
You will find a spring on top which holds the lamp in place which is too tall for gu10
Post #535344 24th Nov 2019 7:42pm
Will run a lot cooler than the CF bulbs too.
LED lights are great, just did our house with all LED bulbs, and all lights switched on (over 100 bulbs) draws less than 600w!
As opposed to 5Kw for the same in old fashioned bulbs! There is nothing that can't be fixed with a hammer😜😜
Post #536506 5th Dec 2019 9:56pm
ilard
For the record, the only concern would be a dimmer switch. Due to low wattage, special dimmers are needed to drive LED lamps. Varilight Pro LED dimmers are exceptionally good in my experience. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #536607 6th Dec 2019 10:44pm
Balloonengineer
Or you can get dimmable LEDS, the sales specs should say if they are dimmable or not.
Usually dimmable are a few pounds more than non dimmable
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #536701 8th Dec 2019 10:50am
