![]() | Home > Technical (L322) > Help please - dropped hose spring retaining clip!!! |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
Are they not simply the spring hose clips ?
TDV8John Member Since: 08 Nov 2015 Location: Kent Posts: 19 ![]() ![]() ![]() |
Hi thanks for the input John but no it wasn't the usual spring hose clip otherwise all would have been well.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
Nino Nino is your man.
OK, I've done a search as I was sure it was a spring clip.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Any clues on this thread
Thanks again guys for the swift help.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
Could you use one of those extending magnetic pens to wave it around in the hope of snagging the clip?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
TDV8John
Mike/Nino
Any help ??
Perfect, that's the one in purple Mike.
You could try hosing down the side of the engine to see if you can wash the clip out. |
Would taking the air filter box out help you to get easier access?.
Yes tried that but no luck unfortunately. |
