Home > Maintenance & Mods (L322) > Supercharger removal
Danwilderspin
Hi all can I remove the supercharger without removing the thermostat housing up front? I want to reduce as few coolant pipes as possible.
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534252 14th Nov 2019 6:45pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hello,
i believe you can, if i remeber correctly its just the hoses that goto the coolers either side that need to come off, maybe acouple of others.
but i did take mine apart about 4 months ago
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #534343 15th Nov 2019 12:40pm
Danwilderspin
No worries - many thanks - on the if I leave the cooler hoses connected can I lift them up at all? I need to change once of the manifold gasket as it leaking but could do without messing around with coolant for the sake of it
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534359 15th Nov 2019 1:41pm
MattHughes86
it might be quite a fiddle but should be do-able, easiest way is to try
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #534362 15th Nov 2019 1:53pm
Danwilderspin
Well spent about 6hours today took the blower out - for anyone doing this a couple of time saving shortcuts -
Unles you want to you can leave the coolant hoses attached to the throttle body and it it to the side - they are long enough.
You don’t need to mess about with the tensioners you can take the bolts out the charger and lift the back up and the belt slips off and vice versa.
Anyway got it all off did a smoke test and had no leaks wtf! So i conceded it must have been somewhere in the blower setup.
Also I had the back supercharger bolt loose which was what my metallic sound was occasionally- vibration I think.
Did the oil too as i literally turn it upside down.
Got it back together and I put a thin film of rtv sealant between all gaskets and no smoke leaks except a tiny one from the bottom of the oil filler?
By far the hardest two things to do we’re to the the bottom offside bolt out of the elbow screwing into the charger and getting the breather pipe off the elbow as the access is pretty poor. The rest is fairly time consuming but straight forward. I actually sat on the side rod the engine for ease.
Anyway hope that helps someone Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #535276 24th Nov 2019 12:03am
MattHughes86
can you explain where the oil is for the super cahrger?
i have mine off and sat in the car but havent looked at it yet.
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #535390 25th Nov 2019 12:21pm
Danwilderspin
there's a torx bolt to the side of the pulley take it out tip it up on its side everyday until empty then refill with syringe,,, Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #535413 25th Nov 2019 4:35pm
MattHughes86
i will have a look at that when i dig it back out.
what oil did you put in?
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #535488 26th Nov 2019 10:41am
Danwilderspin
this bad boy :
https://www.ebay.co.uk/itm/Eaton-M112-Supe...2749.l2649 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #535508 26th Nov 2019 2:02pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Check that it is indeed a torx bolt ... pretty sure it’s an imperial sized Allen head around 5/32 P525
4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #535809 28th Nov 2019 11:54pm
