Home > Technical (L322) > 4.4 TDV8 starter motor or battery... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
The clock resetting indicates a loss of battery power. Check that the battery terminals are clean and tight. |
2nd Dec 2019 8:41pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 343 |
Sounds like total battery drain resetting all electrics, if it was starter it is normally corrosion on terminals in solenoid causing a failure to power the starter. If it is the starter it normally starts after a few attempts ( at first at least ) I would charge battery and see if that effects a cure. If it is the battery you need an 019 AGM replacement. Some people get away without using a IId tool to advise the car it has a new battery. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
2nd Dec 2019 11:26pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
Sounds like battery to me... |
3rd Dec 2019 12:47am |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 390 |
Thank you very much chaps.
3rd Dec 2019 11:23am |
Well, it does appear to have been the battery.
3rd Dec 2019 2:32pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 519 |
It seems to be battery silly season. Wifes fatty battery died on Sunday (looks like it's the original as well, so it hasn't done badly) so getting that replaced. Then, whilst fiddling with radio tuning on my newly picked up fatty, it decided to shut everything down due to insufficient power. Drives:
3rd Dec 2019 5:23pm |
