Home > Maintenance & Mods (L322) > Milk bottle sound help?
Danwilderspin
Hi all
On my 2007 4.2 since I have had it it has had an annoying noise like blowing over a milk bottle - it seems to happen at all speeds doesn’t ever get louder if going fast or slow - occasionally it’s not there.
Had the car since June and lived with it assuming it was due to missing trays and seals however I not have the under trays and all the bonnet seal in place and I still get it?
What’s interesting is it’s barely audible from the passenger seat so it’s definitely over the driver side...
Any ideas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536518 6th Dec 2019 12:23am
mpirie
Have you checked the windscreen trim?
I've had similar issues when one of the gutter trims was raised where it reaches the windscreen.
Some black silicone sealer helped hold it down.
Mike
Post #536536 6th Dec 2019 10:31am
Sandyt
I had the same it was the little square section on the end where it overlaps the top trim on the screen same solution
Post #536540 6th Dec 2019 11:16am
Danwilderspin
it had a new windscreen in the summer (well two as the first one sounded bad!) so maybe? Ar you talking about the thin strips that curl over the top of the windscreen either side?
If so I might stick some duct tape over the sides and go for a drive if it resolves I will silicone- think that would work? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536542 6th Dec 2019 11:35am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Also on the lower edge of the screen to scuttle. When I had mine replaced they forgot to stick it down and it made a terrible racket though not until I got about about 30mph... 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #536552 6th Dec 2019 12:48pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
^^ Yup had it on mine after the screen was replaced. They hadn't reaffixed the scuttle to the lower edge of the screen. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #536553 6th Dec 2019 12:50pm
mpirie
Yep, that's them.
I'm sure there's a fancy name for them, but they cover up the gutters on the roof.
Duct tape would do the job to see if it gets rid of the noise Thumbs Up
Mike
Post #536594 6th Dec 2019 9:33pm
Danwilderspin
Where is this you are talking about? It it what you can see above the bonnet where the scuttle runners are on the screen or under bonnet somewhere?
Thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536709 8th Dec 2019 11:55am
MikeO
The middle of the lower edge of the screen should be bonded to the scuttle panel. 2016 Skoda Octavia VRS Estate
Post #536712 8th Dec 2019 12:31pm
Shesminetoo
Australia 2012 Range Rover Vogue 5.0 SC V8 Fuji White
Hi, I'm interested to know if you solved the problem. My 2011 is going in for service tomorrow, and one ofthe things I want them to check out is this wind/whistling noise starting at or about 80km/hr . Mostly audible from driver side but highly irritating at freeway speeds.
Thanks in advance!
Frans
Post #543055 5th Feb 2020 5:33am
