![]() | Home > Maintenance & Mods (L322) > Milk bottle sound help? |
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
Have you checked the windscreen trim?
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286
I had the same it was the little square section on the end where it overlaps the top trim on the screen same solution |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2297
it had a new windscreen in the summer (well two as the first one sounded bad!) so maybe? Ar you talking about the thin strips that curl over the top of the windscreen either side?
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
Also on the lower edge of the screen to scuttle. When I had mine replaced they forgot to stick it down and it made a terrible racket though not until I got about about 30mph... 2016 Skoda Octavia VRS Estate
| SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173
^^ Yup had it on mine after the screen was replaced. They hadn't reaffixed the scuttle to the lower edge of the screen. 2004 Vogue TD6 - Remapped |
Yep, that's them.
Where is this you are talking about? It it what you can see above the bonnet where the scuttle runners are on the screen or under bonnet somewhere? Thanks Current stable: 2015 5.0 V8 S/C AB 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
The middle of the lower edge of the screen should be bonded to the scuttle panel. 2016 Skoda Octavia VRS Estate
| Shesminetoo Member Since: 18 Dec 2019 Location: Victoria Posts: 10
Hi, I'm interested to know if you solved the problem. My 2011 is going in for service tomorrow, and one ofthe things I want them to check out is this wind/whistling noise starting at or about 80km/hr . Mostly audible from driver side but highly irritating at freeway speeds.
