![]() | Home > Technical (L322) > Strange behaviour since gearbox flush? Any ideas? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35735 ![]() ![]() |
have you mentioned this to JGS4x4? ... - .- -.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
When cold, they hold in gear. It’s normal.
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Thanks both. It is hard to explain, this is/was more than just a simple holding on to the gears and changing a little later. I'm sure it didn't do it before but I do tend to let the car warm up for 3-5 mins at least before driving, this time I pretty much drove straight out, so perhaps a bit colder than normal. I'll see how it is tomorrow, give it the normal warm up and see if it does it.
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
Resetting my 6hp trashed it. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1837 ![]() ![]() |
Edited. 8HP box |
Been reading up online on various forums and resetting the box immediately after a fluid change seems to be a need that is debated. I’ve also seen ways explained to help the gearbox learn again
I would not reset it if it were me.....give it more time to "learn" |
Right ok, so it’s continuously learning, not just in the first x amount of driving following the reset? |
That's my understanding but remember I'm a biologist not a gearbox surgeon |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Don't reset the gearbox. I ruined the ZF6HP on my old Discovery 3 by doing that.
According to our resident gearbox guru Phil Winter, resetting the gearbox is only required when the solenoids have been changed out for new ones, NOT for the fluid/filter change.
That’s great thanks, sending pm with email address now.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3837 ![]() ![]() ![]() |
It is a couple of years since I had mine done and they did reset the software.
Bodsy rechecked my fluid level post flush when machine was disconnected and pipe system put back together. Got the box up to temperature (iid confirmed that) then he took the filler plug out and topped up as required. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
