Home > Technical (L322) > Strange behaviour since gearbox flush? Any ideas? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
have you mentioned this to JGS4x4? ... - .- -.
9th Dec 2019 5:45pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
When cold, they hold in gear. It’s normal.
9th Dec 2019 5:49pm |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 |
Thanks both. It is hard to explain, this is/was more than just a simple holding on to the gears and changing a little later. I'm sure it didn't do it before but I do tend to let the car warm up for 3-5 mins at least before driving, this time I pretty much drove straight out, so perhaps a bit colder than normal. I'll see how it is tomorrow, give it the normal warm up and see if it does it.
9th Dec 2019 6:17pm |
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 |
Resetting my 6hp trashed it. |
9th Dec 2019 8:32pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1691 |
Edited. 8HP box |
9th Dec 2019 8:53pm |
Been reading up online on various forums and resetting the box immediately after a fluid change seems to be a need that is debated. I’ve also seen ways explained to help the gearbox learn again
11th Dec 2019 8:16am |
I would not reset it if it were me.....give it more time to "learn"
11th Dec 2019 8:19am |
Right ok, so it’s continuously learning, not just in the first x amount of driving following the reset? |
11th Dec 2019 8:22am |
That's my understanding but remember I'm a biologist not a gearbox surgeon
11th Dec 2019 8:24am |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Don't reset the gearbox. I ruined the ZF6HP on my old Discovery 3 by doing that.
11th Dec 2019 8:46am |
According to our resident gearbox guru Phil Winter, resetting the gearbox is only required when the solenoids have been changed out for new ones, NOT for the fluid/filter change.
11th Dec 2019 9:02am |
That’s great thanks, sending pm with email address now.
11th Dec 2019 9:26am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3674 |
It is a couple of years since I had mine done and they did reset the software.
11th Dec 2019 9:48am |
Bodsy rechecked my fluid level post flush when machine was disconnected and pipe system put back together. Got the box up to temperature (iid confirmed that) then he took the filler plug out and topped up as required. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
11th Dec 2019 10:26am |
