![]() | Home > Technical (L322) > Restricted Performance - what is this fault code pointing to |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Oh and when I clear the fault, it comes straight back again. When I click the “i” I get this info.....
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic50202.html?highlight=p040d 2006 4.2 SC |
Wasn’t 100% sure that code was the cause of my
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
M@r]{ if you've read the link spud posted above, you'll see that code definitely isn't the cause of your restricted.
Oh I was all proud of myself that I'd used my £400 tool and found the cause of my problem |
BTW that write up on replacing the sensor is legendary!! Fantastic! The rounding off of the sensor is a bit worrying though. Is there any negative effect of this sensor misbehaving like this? If not I'm wondering whether to just leave it be, the idea of it rounding off and needing a manifold off job does not appeal!! |
Donut hoses - easy job and not expensive.
Do a search on Restricted Performance and you can get the gist of the usual suspects.
Fingers crossed it is just one of those silicon hoses. I'll get the engine cover off in the morning and have a look. Found 1m of 70mm hose on ebay for just over £20. If I can get it delivered by next Friday I can ask the garage fitting my starter motor to do those as well |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
You're definitely doing the right thing and getting all the usual things sorted on it |
