|  | Home > Technical (L322) > Restricted Performance? Could this be the culprit? - FIXED! |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Stent it as a short term fix and check it regularly.
|  14th Dec 2019 3:28pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | LR029140 on my invoice   | ||
|  14th Dec 2019 3:49pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | https://www.island-4x4.co.uk/hose-genuine-lr029140-p-38388.html
|  14th Dec 2019 3:52pm |
| M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165      | Found one here, £85 inc delivery by Tuesday
|  14th Dec 2019 4:06pm |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198      | It's quite easy to fit, don't bother trying to remove the broken part of the fitting, remove the hoses etc complete  tomorrow. You can see where the part fits from the picture in the suppliers parts section and follow that through on the car. You're ready to go and it will take 30 minutes, which should include refilling whatever came out. In fact if you fill the system as far a possible you'll be ahead of the game.
|  14th Dec 2019 4:26pm |
| M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165      | No, appreciated.  My mechanical skills are limited to say the least.  I should have left it alone, it's now cost me £85 plus a load of aggravation.
|  14th Dec 2019 4:32pm |
 All been there. Hang in there, get all the bits done and it will be fine. Trust me, I’m a Dr  Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- | ||
|  14th Dec 2019 4:34pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Have you got AA cover? See if they will come and do it   | ||
|  14th Dec 2019 4:35pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001      | My connector broke whilst driving back in May. I managed to swap the pipes with the new part. Didn’t take that long.
|  14th Dec 2019 4:43pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Try cleaning the inlet manifold pressure sensor, the sensor you can easily get to on the top of the big plastic donut manifold. They can fill up with crud and read wrong hence you get a low pressure reading. There is nothing that can't be fixed with a hammer😜😜
|  14th Dec 2019 4:58pm |
| M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165      | Thanks for the words of encouragement, I need it right now!  | ||
|  14th Dec 2019 5:02pm |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198      | The right angle connector is fairly simple to remove, but if you have ANY  worry, then you could carefully cut the hard plastice pipe off that connector and remove the broken piece from the other end,  Then use a suitable piece of pipe from a car parts shop to fit in its place, secured with a couple of hose clips. That would let you simply change out the connetion piece that was broken.
|  14th Dec 2019 5:06pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Have you swapped out your new top hose yet? Hope it went OK   | ||
|  18th Dec 2019 12:30pm |
| M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165      | Yes did it last night under torch light! But yes went all ok. Car is booked in to a garage to have a new starter fitted and a smoke test, so hopefully will get an idea on what the issue is by the end of the week | ||
|  18th Dec 2019 5:44pm |
| Posting Rules
 ) and get one. Ask for discount as you are a forum member
