![]() | Home > Technical (L322) > Restricted Performance? Could this be the culprit? - FIXED! |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Stent it as a short term fix and check it regularly.
LR029140 on my invoice |
https://www.island-4x4.co.uk/hose-genuine-lr029140-p-38388.html
| M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165
Found one here, £85 inc delivery by Tuesday
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
It's quite easy to fit, don't bother trying to remove the broken part of the fitting, remove the hoses etc complete tomorrow. You can see where the part fits from the picture in the suppliers parts section and follow that through on the car. You're ready to go and it will take 30 minutes, which should include refilling whatever came out. In fact if you fill the system as far a possible you'll be ahead of the game.
No, appreciated. My mechanical skills are limited to say the least. I should have left it alone, it's now cost me £85 plus a load of aggravation.
All been there. Hang in there, get all the bits done and it will be fine. Trust me, I’m a Dr 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
Have you got AA cover? See if they will come and do it |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
My connector broke whilst driving back in May. I managed to swap the pipes with the new part. Didn’t take that long.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Try cleaning the inlet manifold pressure sensor, the sensor you can easily get to on the top of the big plastic donut manifold. They can fill up with crud and read wrong hence you get a low pressure reading. There is nothing that can't be fixed with a hammer😜😜
Thanks for the words of encouragement, I need it right now! |
The right angle connector is fairly simple to remove, but if you have ANY worry, then you could carefully cut the hard plastice pipe off that connector and remove the broken piece from the other end, Then use a suitable piece of pipe from a car parts shop to fit in its place, secured with a couple of hose clips. That would let you simply change out the connetion piece that was broken.
Have you swapped out your new top hose yet? Hope it went OK |
Yes did it last night under torch light! But yes went all ok. Car is booked in to a garage to have a new starter fitted and a smoke test, so hopefully will get an idea on what the issue is by the end of the week |
| All times are GMT |
