Home > General > LR Specialist issues - wrong oils - what to do?
jackie-o
Netherlands
Hi all,
So recently became a proud owner of a 2011 RR Vogue with 75.000 miles on it.
Bought the car in the Netherlands and wanted it serviced before a 2.000 KM drive home to Sweden. Long story short I left it to a "specialist" to do a an oil change, diffs/transfer case and replace both xenon head lamps.
Upon picking up the car and leaving they gave me a litre of engine oil in case it was needed on the way back - nice guys.
However, I noticed (thanks to a recent thread on this forum) that the oil specification was for the 3.6 TDV8 and not my 4.4 TDV8.
Upon questioning them on this it turns out they have no idea what kind of oil they´ve put in the car Mad
I had a quick chat to camtech craig who advised me not to drive it. Unfortunately i had to get back to Sweden so made the drive anyway.
Now my question;
1. How do I "clean" the engine and make sure all wrong oil is out so that I can fill it up with correct oil?
2. How wrong can it go by having incorrect differential/transfer case oils? I get a feeling these will not be the correct spec either Yawn
3. Can these just be drained and replaced or will this also require some kind of cleaning?
As always, all answers greatly appreciated! I also need to know the extent of extra work needed as I will demand a full refund from the "LR Specialist" as soon as possible.
Many thanks in advance! RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #537560 15th Dec 2019 8:08pm
GGDR
Most here use the Shell Helix Ultra Professional AF-L 5W-30
It needs the L
You can get a flushing agent, some people use it before oil changes.
You put a can in, run the engine for a short bit then drop your oil.
Like this: https://www.wynns.eu/product/engine-flush/
. Cheers, Greg
Post #537565 15th Dec 2019 8:23pm
I would do 2 changes dropping the oil from the bottom connector on the sump., don’t bother with changing the filter on the first change, just loosen it off to let the oil drain down. Then change the filter on the second swap. that should flush the old oil out well enough imho.
In terms of the diffs, I would be more worried about them being overfilled, as they require an amount of oil rather than filling to overflowing the hole.
There is a spec for the oils in the wiki, I would drain and refill front rear and transfer box with the specified quantities. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #537566 15th Dec 2019 8:25pm
jackie-o
Netherlands
Thanks Greg!
Any thoughts on differentials and/or transfer case fluids?
How bad is it if they are also wrong? RR Vogue 4.4 TDV8 - 11
Post #537567 15th Dec 2019 8:25pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
No idea how it works in Holland, but if you have made a round trip of 4000 km after a documented and 'published' possible oil error then I doubt very much that the garage will in any way stump up for any subsequent rectification.
Even your odometer will inform the garage that you have driven such an enormous distance after being made aware of the possible error and another specialist has also told you not to drive it. cf, your post here.
I sincerely hope that you have nothing more than an early oil change to pay for.
Best, Rich
Post #537568 15th Dec 2019 8:28pm
jackie-o
Netherlands
Thanks NMJ!
Would you recommend running the car any specific distance between first and second change?
This forum is truly priceless Smile RR Vogue 4.4 TDV8 - 11
Post #537569 15th Dec 2019 8:29pm
jackie-o
Netherlands
Hi Rich,
The refund situation is a whole other topic but in essence they guaranteed me that they put the correct engine oil in the car after I took it back the next day. I would however bet my last dollar that this is incorrect - based on several factors. RR Vogue 4.4 TDV8 - 11
Post #537570 15th Dec 2019 8:35pm
RichM63
But you then decided to drive it a return trip of 4000 km, thus you agreed with them!
Get the oils changed again, somewhere else, clearly the car has so far survived.
And will continue to do so.
Best, Rich
Post #537573 15th Dec 2019 9:33pm
Not far - you're basically just diluting the wrong oil.
A single change will leave a certain amount of residual wrong oil and once mixed with the new oil, a second change would remove the vast majority of that
Post #537577 15th Dec 2019 9:54pm
jackie-o
Netherlands
brilliant Alistair, thanks! RR Vogue 4.4 TDV8 - 11
Post #537578 15th Dec 2019 10:03pm
jackie-o
Netherlands
Best, Rich
Pretty pointless discussion for the two of us to have but...I think that if they´ve put the wrong oil in to begin with and then, intentionally or not, lied about it instead of fixing it - why should I have to pay for the service?
Specially as the effect will be me having to spend twice the money again doing double oil changes to rectify their mistakes?
Makes little sense to me at least... RR Vogue 4.4 TDV8 - 11
Post #537579 15th Dec 2019 10:08pm
Get the oil changed
Send them the bill
Expect nothing & take anything they give you as a bonus.
Post #537581 15th Dec 2019 10:12pm
As Alistair said. Thumbs Up
It shouldn’t do it much harm to have that oil in for a couple of 1000k especially as it was presumably mostly running long distance with the engine warm.
Most engine wear occurs when the engine is cold. The newer spec oil is low SAPS which produces is supposed to reduce the amount of spot going through the DPF. In theory any potential damage would be to the DPF. but as presumably you were running hot then that damage would likely be kept to a minimum. If you have an diagnostic tool it may be possible to see if the DPf needs a regen cycle. There is nothing that can't be fixed with a hammer😜😜
Post #537582 15th Dec 2019 10:14pm
jackie-o
Netherlands
Thanks for all replies and advice!
All fluids changed and fresh.
Can hopefully start enjoying the car Very Happy RR Vogue 4.4 TDV8 - 11
Post #537747 17th Dec 2019 11:21pm
