![]() | Home > Technical (L322) > Auxiliary coolant pump & FBH |
Watching this with interest as I have the same issue - wondering if somethings not wired up correctly/loose/fallen off |
Nathan v8 Member Since: 04 Dec 2019 Location: South Wales Posts: 15 ![]() ![]() ![]() |
My one was working until a few weeks ago....... |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Got the same thing on mine recently so decided to have a look at it today - here's my experience based on what I've read/tried so far
I've just done the same. Will report back |
I did try Pulling the fuse.. will give it another go tomorrow see what happens.
Didn’t work for me. FBH starts up then stops after a few minutes. Theres an accompanying ticking noise from the rear of the car. Starts at about one per second then picks up to about twice per second, then it cuts out. No heat coming through. Further investigation required I think 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
The ticking noise at the back will be the fuel pump my one makes that noise so that’s good...
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 670 ![]() ![]() ![]() |
The pump next to the heater valves only runs for aux residual heating afaik, the aux pump for the FBH is actually bolted onto the FBH and controlled by the FBH. That’s my understanding from the workshop manual and how our 2007 worked.
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Just ordered a new FBH pump. Any tips for replacing it? Is access ok once whenwheel arch liner is out? |
You can get to it without removing the FBH, but I prefer to remove the few bolts and take the FBH out to improve access. You’ll need a couple of hose clamps, and I think a Torx bit for the bolt that holds the pump onto the FBH.
Thanks for that. I'll give it a go |
I think my pump has gone I will try and have a look / test it tomorrow..
Yep pump is dead.. wont power up.. looks simple enough to change |
Fixed it
