Home > Technical (L322) > Auxiliary coolant pump & FBH
Nathan v8
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi 1st post....
I have a 3.6 2008 L322 I can’t get heat in the cab from the FBH.
The fbh works I believe the problem is as follows.
If I turn the ignition on turn the fan on I get 12v to the pump next to the heater valves and the pump runs as it should.
If I set or manually use the parking / aux heater (FBH) there is 0v going to the pump. The fbh fires up and I can feel the coolant pipes around the pump and valves worming up but the pump is not running.
I gave the pump 12v when the FBH was running and got worm air in the cab.
Anyone ever had that fault and any idea how to solve it?
Post #538978 31st Dec 2019 10:36am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Watching this with interest as I have the same issue - wondering if somethings not wired up correctly/loose/fallen off Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #538982 31st Dec 2019 11:07am
Nathan v8
My one was working until a few weeks ago....... Confused
Wondering if it’s a ECU problem
Post #538987 31st Dec 2019 12:22pm
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Got the same thing on mine recently so decided to have a look at it today - here's my experience based on what I've read/tried so far
It could be that the pump could be in lockout mode - there's a pdf in the Wiki about how it all works https://www.fullfatrr.com/gallery/albums/u...er_fbh.PDF
, but essentially if it fails to start correctly three times under certain conditions in goes into lockout mode. It then needs to be reset either by the dealer (erm, no!) or by disconnecting the power for 10 seconds. You can achieve this by pulling the fuse out, or disconnecting the battery.
On my 2009 3.6 it's fuse 59 behind the glovebox, bottom row, second from the right, but check your manual to make sure. It's described as "Auxilliary heater (diesel models only), Independent heater". I just pulled this, counted to 10 and popped in back in. So far it seems to be working normally now as I can hear it all firing up when I press the remote, but I won't know for sure that I'm getting hot air through the cabin until the car cools down overnight and I can try it properly 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #539016 31st Dec 2019 3:52pm
DMRR
I've just done the same. Will report back Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #539029 31st Dec 2019 5:50pm
Nathan v8
I did try Pulling the fuse.. will give it another go tomorrow see what happens.
Thanks
Post #539031 31st Dec 2019 5:56pm
Tugger
Didn’t work for me. FBH starts up then stops after a few minutes. Theres an accompanying ticking noise from the rear of the car. Starts at about one per second then picks up to about twice per second, then it cuts out. No heat coming through. Further investigation required I think 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #539046 31st Dec 2019 7:49pm
Nathan v8
The ticking noise at the back will be the fuel pump my one makes that noise so that’s good...
It’s just not sending power to the auxiliary coolant pump ... when I provided power to the pump myself I got heat in the cab..
Post #539050 31st Dec 2019 8:24pm
TJH1985
The pump next to the heater valves only runs for aux residual heating afaik, the aux pump for the FBH is actually bolted onto the FBH and controlled by the FBH. That’s my understanding from the workshop manual and how our 2007 worked.
We had two fail in 5 years of ownership, you have the have the arch liner out to get at it. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #539067 1st Jan 2020 1:19am
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Just ordered a new FBH pump. Any tips for replacing it? Is access ok once whenwheel arch liner is out?
Post #539082 1st Jan 2020 10:58am
TJH1985
You can get to it without removing the FBH, but I prefer to remove the few bolts and take the FBH out to improve access. You’ll need a couple of hose clamps, and I think a Torx bit for the bolt that holds the pump onto the FBH.
It takes around 30 minutes, including cleaning up behind the arch liner etc I gave everything a coating in Dintrol the first time while the arch liner was off.
Post #539096 1st Jan 2020 12:49pm
gilesharrison
Thanks for that. I'll give it a go
Post #539146 1st Jan 2020 10:50pm
Nathan v8
I think my pump has gone I will try and have a look / test it tomorrow..
What’s the best place to order one?
Post #539155 2nd Jan 2020 1:00am
Nathan v8
Yep pump is dead.. wont power up.. looks simple enough to change
Post #539212 2nd Jan 2020 6:08pm
Nathan v8
Fixed it
Used a disco 3 circulation pump cut the plug off and soldered the one off the old pump onto it.
All working back to having a worm cab in the mornings.
Post #540070 10th Jan 2020 6:18pm
