![]() | Home > Maintenance & Mods (L405) > key fob |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
Much appreciated Stan |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
you must have little spindly fingers then |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
Well the key fob actually arrived today from China, I haven't opened it up yet but it certainly looks promising.
looks like a nice fob Geoff..
Actually I found it pretty easy, used the locating lugs to locate with the corresponding holes on the PCB and put it back together only to find a couple of buttons no longer worked (they lined up perfectly and worked before). I realised that this was due to the fact that the back of the PCB needed supporting and I did it by bending the thing that puts the pressure on the back of the battery up a bit, foam tape or similar would probably work as well, might even be better !
Although it appears to have gone up a couple of quid this is the fob I ordered.
i like it..if you fancy selling give us a shout geoff... ... - .- -.
Stan, I'll send a PM Geoff |
