Home > Maintenance & Mods (L405) > Headlight condensation and LED's
Doodle
405 is now 15 months old and has headlight condensation both sides.
Offside one third all across full length at bottom and nearside one quarter halfway across bottom.
Never pressure washed
In now looks as if some new bacteria is taking over in there. (Could be the one medical science is looking for to combat super bugs?)
Anyway, my post is asking why the xenon's heat does not dissipate the moisture.
Additionally, as LED's produce almost no heat and will be fitted to 405's soon, how will the headlight binnacle free itself of moisture ingress? New Discovery also?
Will be off to dealers who will probably say, 'it's ok, they all do it!!!' Laughing
Post #415358 25th Nov 2016 6:24pm
Charlyfarly
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
"Additionally, as LED's produce almost no heat and will be fitted to 405's soon, how will the headlight binnacle free itself of moisture ingress?"
Never mind binnacle's, you'll soon have barnacle's Smile If it ain't broken, fix it till it is.
Post #415360 25th Nov 2016 6:28pm
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
I have moisture in both headlamps too now. Did the dealer sort yours? 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #540055 10th Jan 2020 3:55pm
theres a sort of disclaimer in the owners manual, no help to the end user..
Post #540058 10th Jan 2020 4:31pm
Jase71
Thanks Stan. Thing is, my car is nearly 3 years old and it has only started doing this in the last couple of months. If it happened from new their disclaimer would makes sense Shocked 2017 Range Rover Vogue V6 Diesel
Post #540064 10th Jan 2020 5:17pm
CS
Mine has condensation on both sides. I have sent pictures to the dealer and the lights will be checked at the next service later this month. They told me that depending on severity this might be the subject of a warranty claim, in which case the light units would be replaced. I had not remembered the handbook comment, but the lights do seem to work normally. Like Jase71 mine seems to have started doing it recently rather than from new, though it is possible that i have just not noticed earlier.
The condensation appears when the lights are on, and disappears again when they are off. An earlier thread on here said that the heat from the lights opens the seal on the light unit and it then closes again when the lights are off. I don't know whether that is the reason. I'll try to remember to update this after the service. Only Range Rovers since 1988
Post #540071 10th Jan 2020 6:33pm
could bd a batch if faulty 2017 headlight units? ... - .- -.
Post #540075 10th Jan 2020 7:13pm
Remember this is the wettest period (certainly that i can remember!)
All of the lights (certainly the plastic lensed ones) on all of our cars are misting on and off at present!!! Even the lights on my FF which are less than a month old!
Post #540083 10th Jan 2020 8:19pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I'd say your right Craig, I live on a farm and have recently seen water standing In places I've never seen before. That said, I'd have thought the headlights should be effectively sealed. I don't recall seeing this problem on sealed beam units of cars made donkeys years ago.
Post #540088 10th Jan 2020 9:16pm
Jase71
Tried to get a good shot but this is a milder version of what’s happening. It does go away when the car is parked and appears to be as a result of running the lights. 2017 Range Rover Vogue V6 Diesel
Post #540181 11th Jan 2020 2:28pm
Take an interest also in the internal condensation on the windows as the weather is at the moment! Ill bet you they are excessively misting up too! Im sure its just normal for this weather "which is abnormal!" folks... Thumbs Up
Post #540190 11th Jan 2020 3:32pm
CS
No window condensation for me. In my case at least it does seem light specific. Only Range Rovers since 1988
Post #540227 11th Jan 2020 5:51pm
Jase71
Me too, only lights and only this year.. 2017 Range Rover Vogue V6 Diesel
Post #540252 11th Jan 2020 9:49pm
this pdf from the WM explains all about condensation,
http://www.fullfatrr.com/gallery/albums/us...ESTING.pdf ... - .- -.
Post #540260 11th Jan 2020 10:36pm
CS
That's very useful. Mine seem to get condensation only after running with the lights on for some time, say 50 miles, which is counterintuitive as one would expect the heat from the lights to dry them off, and also inconsistent with LR's narrative. The pictures I have sent to the dealer (both sides) have the drip streaks shown in one of the pictures in the LR instructions, but i have not seen standing water inside the lights. I'll report what they say. Only Range Rovers since 1988
Post #540307 12th Jan 2020 2:42pm
