Home > Maintenance & Mods (L405) > 2016/2018 exhaust |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1245 |
Any pics so we can understand better? picture of your exhaust tip and what you are trying to fit would help? |
10th Jan 2020 10:23pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 378 |
Hi DrF,
10th Jan 2020 10:36pm |
The 2018 has a different rear bumper to that of the 2016MY only difference is to house the exhaust tips as they are fitted to he bumper itself, I have one of each (both supercharged) and have just looked at mine and i would say the tips would fit from a quick glance without adjustment. I would stick to original equipment bumper as i wouldn't want to be playing around with exhaust fumes at the rear. From what i understand its easy enough to facelift the rear bumper with original equipment bumper. Plenty have done it and there are plenty of 2018 bumpers on the web for sale cheaply. Hope that helps.
10th Jan 2020 11:00pm |
Thank you so much for the info! So technically, I could just buy the 2018 exhaust tips and retro fit them to my 2016 bumper correct? There is the video on you tube showing the 4 different bumpers but for the 2018, they just have the tips lying on top of the underside of the bumper so hard to see how they attach. Mike |
10th Jan 2020 11:50pm |
Hi Sorry no you need the 2018 bumper as they fit to the bumper itself, the 2016 cant be adapted to accept the tips from a 2018. |
10th Jan 2020 11:55pm |
Understand. Thanks!!! |
10th Jan 2020 11:56pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Funnyguy, if you want to fit 2018 tips then as DrF says above, the 2018 factory standard rear bumper is completely different to your 2012-2018 and is built to house the larger tips...
11th Jan 2020 12:10am |
Thanks Craig,
11th Jan 2020 12:16am |
These are SVAutobiography
11th Jan 2020 12:23am |
Then you will need to replace your entire bumper sir |
11th Jan 2020 12:32am |
Hi Craig,
11th Jan 2020 2:53am |
Hi,
11th Jan 2020 10:26pm |
Yes the 2018 bumper will bolt straight on sir but! Weather you need to change anything with your exhaust ends? I simply do not know? |
11th Jan 2020 10:44pm |
Thanks Craig! |
11th Jan 2020 10:47pm |
