Home > Maintenance & Mods (L405) > 2016/2018 exhaust
funnyguy1
United States
2016/2018 exhaust
Can anyone tell me if the rear exhaust for the 2016 L405 is the same as the 2018?
Watching the PowerfulUK video on the different bumpers, it appears they are similar. Trying to mount a set of the stainless steel exhaust tips from a 2018 onto my 2016.
Post #540097 10th Jan 2020 10:01pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Any pics so we can understand better? picture of your exhaust tip and what you are trying to fit would help?
Post #540101 10th Jan 2020 10:23pm
funnyguy1
United States
Hi DrF,
Here are 2 pics. my 2016 has the exhaust tips pointing down. Starting in 2018 the incorporated the stainless steel straight out pipes you can see in 2nd pic. There is also a video on youtube showing all 4 l405 bumpers and there differences. It appears the actual exhausts for the 2 are the same. Was just wondering if I could adapt the 2018 stainless exhaust tips to my 2016. Thx! M
Post #540103 10th Jan 2020 10:36pm
DrF
The 2018 has a different rear bumper to that of the 2016MY only difference is to house the exhaust tips as they are fitted to he bumper itself, I have one of each (both supercharged) and have just looked at mine and i would say the tips would fit from a quick glance without adjustment. I would stick to original equipment bumper as i wouldn't want to be playing around with exhaust fumes at the rear. From what i understand its easy enough to facelift the rear bumper with original equipment bumper. Plenty have done it and there are plenty of 2018 bumpers on the web for sale cheaply. Hope that helps.
Keep us posted on your efforts and good luck. Thumbs Up
Post #540109 10th Jan 2020 11:00pm
funnyguy1
United States
Thank you so much for the info! So technically, I could just buy the 2018 exhaust tips and retro fit them to my 2016 bumper correct? There is the video on you tube showing the 4 different bumpers but for the 2018, they just have the tips lying on top of the underside of the bumper so hard to see how they attach. Mike
Post #540121 10th Jan 2020 11:50pm
DrF
Hi Sorry no you need the 2018 bumper as they fit to the bumper itself, the 2016 cant be adapted to accept the tips from a 2018.
Post #540122 10th Jan 2020 11:55pm
funnyguy1
United States
Understand. Thanks!!!
Post #540123 10th Jan 2020 11:56pm
Funnyguy, if you want to fit 2018 tips then as DrF says above, the 2018 factory standard rear bumper is completely different to your 2012-2018 and is built to house the larger tips... Thumbs Up
However! If you want to fit a 2018 "type" exhaust then you can retro fit the SVAutobiography exhaust finisher & panels to the underside of your 2012-2018 standard rear bumper! Because... JLR in there wisdom took off the 2018> rear bumper and fitted a modified 2012-2018 rear bumper to the 2018> SVAutobiography models! Go figure.........
Below is the 2018 SVA rear fitted to my car Thumbs Up
Post #540124 11th Jan 2020 12:10am
funnyguy1
United States
Thanks Craig,
Are the SVAutobiography tips different than the 2018 regular tips? I have been using that PowerfulUK youtube comparison showing 4 different bumpers 3 showing tips but the one i think looks best is the one we have been discussing. Very low profile.
Post #540126 11th Jan 2020 12:16am
These are SVAutobiography
https://www.ebay.co.uk/itm/Range-Rover-Vog...SwXrld4SGz
These are standard 2018
https://www.ebay.co.uk/itm/Range-Rover-Vog...Swfrld1o91
Post #540127 11th Jan 2020 12:23am
Then you will need to replace your entire bumper sir Thumbs Up
Post #540128 11th Jan 2020 12:32am
funnyguy1
United States
Hi Craig,
Yes, I just figured that out, but will the 2018 bolt right in?
Thanks for your help!
Mike
Post #540133 11th Jan 2020 2:53am
funnyguy1
United States
Hi,
So I can't get any help from Land Rover or various body shops on whether the 2018 is interchangeable with the 2016?
Post #540257 11th Jan 2020 10:26pm
Yes the 2018 bumper will bolt straight on sir but! Weather you need to change anything with your exhaust ends? I simply do not know? Thumbs Up
Post #540261 11th Jan 2020 10:44pm
funnyguy1
United States
Thanks Craig!
Post #540262 11th Jan 2020 10:47pm
