Home > In Car Electronics (L322) > Headunit Upgrade on 2006-2010 - Work in progress
Page 1 of 3 123>
Danwilderspin
Hi all,
A while back i mentioned that my rear headrest screen one was always broken since I had the car then the second one died and within about a month the laser died in the dvd changer.
I thought time for an upgrade as I won’t be losing anything with the rears here.
I purchased this bad boy:
https://a.aliexpress.com/6S39NIXDp
This
https://a.aliexpress.com/Kyu5TGD91
This
https://a.aliexpress.com/mJKm3V5ab
This
https://a.aliexpress.com/poycyWuIr
And finally this:
https://avinusa.com/most-fiber-optic-amp-i...ander.html
specifically noting the head unit does have rear screen outputs once I find some screens the right size. This is fairly low priority but will happen at some point.
I then bought a jaguar m to iso f connector and then a bmw f to iso m connector and plugged them together.
I ran an ibus feed (we still have it!!) from the clock (spliced) to the ibus input on the headunit and an ignition live from the cigar lighter.
Plugged the dab/CarPlay usbs in, plugged the front rcas from the head unit into the most box and splice then into the loom. I plugged one end of the most cable in and the loosely ran it over the seats and unplugged the old one from the amp and replaced with this.
Put the key in to test and all worked.
I then fitted it properly. Unfortunately unlike the early dash on the l322 it’s very tight I had to trim
The back of the head unit to make it fit (there’s a big nearly empty metal box on the back. However make sure it all works first as this will definitely kill your warranty!!!)
Eventually got it all in and all is well except I have a bit of a hiss when no music plays like the amp
Is set to full gain. I am waking on a replacement most adapter on this.
The dab window area is pants so may get a shark for this.
I can’t get the stock reverse cam to work but I’m not giving up yet
I can’t set the time but the resler interface looks like it may be the way along with ibus app.
I will keep this updated and add pics over time.
Overall very impressEd there’s a decent dsp on the head unit so excusing the bow sound hiss with music playing the sound system sounds so much better than before (no complaints before either!)
The whole upgrade had cost around as much as one nav tool box but you get a whole load more and a massive screen.
If you have the touch screen and no rse I’d say this is a no brainer. With the rse it’s a bit of a toss up.
Here’s a pic
 Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #538858 29th Dec 2019 9:01pm
ur20v
A Trap
Good to see options coming for 2006+ FF’s.
Hope you fully work through the issues, keep us posted 👍
Post #538979 31st Dec 2019 9:36am
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Great Progress
Quick Question: (as I have a 2008) - do you loose access to the 4X4 section? I would assume so. 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #539040 31st Dec 2019 5:54pm
Danwilderspin
Yea you do didn’t bother me too much terrain response wheel still works but nothing on screen Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #539058 31st Dec 2019 9:59pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
This looks excellent. I'm just looking into option to upgrade the clunky system in my '07 with rear screens. Are there any plug and play options that'll work with current screen and buttons on the steering wheel etc.? 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #539554 5th Jan 2020 9:16pm
Danwilderspin
Morning - this works fine with the steering wheel for volume / skip and voice button. you lose the 4x4stuff obviously. What screen are you referring to?
Ive now seen they do a slimline version of this which should drop straight in however I don't believe it has rear screen outputs... Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #539579 6th Jan 2020 9:37am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi mate which one is the slimline version you mention do you have a link please cheers. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #540158 11th Jan 2020 10:24am
Danwilderspin
Hi there it’s this I have not tried it and you need to check it dit’s but from the picture it looks ok...
https://a.aliexpress.com/Yi86VQbon Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #540247 11th Jan 2020 8:19pm
Danwilderspin
Update...
So gone back and fourth and it seems the interference/hiss wasn’t from the most adapter (it makes a slight hiss but you can’t hear this with the engine running so it’s perfectly liveable) but form the head unit itself. I’ve been going back and fourth with the seller but I’ve caved and bought a cyrus usb dac from richersounds and an android app for £3.50 and the quality is fantastic now and I get NO interference (hooray) however the dac outputs at a high voltage so I can only turn the volume up to 1/3. May try a dragon fly dac next as the voltage is less.
Only problem with this... I can’t control any left right fade or bass /treble . Not a big issue as it’s perfectly calibrated dac but worth knowing.
Also with my carplay and now dac I am out of USB ports. I have an ibus interface on the way and a dash cam so I’ve had to invest in a powered usb hub for the next phase... Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #540363 12th Jan 2020 8:51pm
tveitan
Norway 2002 Range Rover HSE Td6 Oslo Blue
Hi! screen looks really good in your car. I have just connected mine in the boot to see if everything works, and i'm quite pleased with the unit. looking forward to getting it installed properly.
Like you, it looks like i'll be short on usb ports. Have you tried using a usb hub yet? Do you know for sure that it needs separate power, or is it possible the power from the usb port will be sufficient? 2002 Range Rover Td6
Post #543026 4th Feb 2020 7:37pm
Danwilderspin
I bought one off of amazon and used the cigar lighter to power it as on the 06+ it is ignition live - all working well on that front.
I can get navcoder to see the ibus traffic but I can’t activate the ibus app on the unit as it reads the vin from the light module which as it’s different it can’t see! Doh Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #543050 4th Feb 2020 11:45pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Thats a smart looking option Thumbs Up
Post #543058 5th Feb 2020 7:52am
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
Hi Dan
any sound clips / videos?
Post #543059 5th Feb 2020 7:52am
tveitan
I will have to find a different power source since mine is 2002. Do you have a link to the hub? Does the hub run on 12V or do you have a converter?
That's annoying... Hopefully there is a workaround for it.
EDIT: Just thought of something, according to iBus installation guide you cannot use a usb hub, otherwise the app won't recognize it. Have you tried the ibus connected directly to one of the usb ports on the unit? 2002 Range Rover Td6
Post #543075 5th Feb 2020 9:31am
Danwilderspin
interesting - i will have to see if i can make it reach to try it
this one:
https://www.amazon.co.uk/gp/product/B074H9...&psc=1
Will try and get a video of the system at some point. cheers Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #543085 5th Feb 2020 11:10am
Page 1 of 3 123>
