![]() | Home > Technical (L322) > suspension bong |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Here we go again after 18 months of trouble-free suspension faults the bong starts when I turn the ignition on, if I turn off the light goes out, I have changed the compressor and a ride-height control 18 months ago.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Interior motion? That’s the alarm sensor isn’t it? Not sure why that affects yor suspension. Not sure if this helps but on the earlier l322 models the bcu was under the pax seat and easy to get out and examine or change. A new one was c. £200 iirc. |
Hi, It states B112C-96 (2F) Interior motion sensor-Component failure-internal failure
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Hi Tinman
Now that you have pointed out about the motion sensor in the roof before I got the Bong I had locked the car and walked away and the alarm went off for no reason? I want back to the car unlocked opened the driver's door closed again and locked it no more alarm going off just the Bong only now and again?
Door open and the suspension won't change height. AFAIK the motion sensor does that, not check the doors' closed. (try leaving the sunroof open and setting the alarm, you'lll get the alarm going off a 2 in the moring, trust me I know |
Up-date to the Bong, I can not use the height control buttons when the yellow triangle is showing which is obvious,
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1031 ![]() ![]() |
All a bit odd that I'm in kent to if you want to swing by I can plug my Hawkeye in and see if that agrees with your diag |
Many thanks for the offer I am currently in the south of Spain for the winter had some good weather up until yesterday and today getting blown around from the tail end of a very bad storm 60/80 Kph gust which is sure rattling the tin tent no sleep
Yes Tinman give me a shout when your back |
The light came and went which was very strange and the fault code I was reading had nothing to do with the problem?
Update to my last post in addition to the Battery post? Changed battery? Now I have been told that I need a new suspension compressor which |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
Sorry to read about your trouble Tinman...
Thanks for your reply Craig I will take your thoughts on board, In my case when you press the switch to move the suspension to vent you can hear it start to go then stop I found this out by opening up the cover on the compressor and taking the filter off to check it was not blocked? |
