![]() | Home > Technical (L322) > 4.4TDv8 cap on oil extraction pipe |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Mine has one and I would of assume yours should too. 2015 4.4 AB
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Should have a cap. |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
Hi, I have the same problem.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
Get a short piece of plastic tubing like in the picture in the last post, then find a suitable size bolt to fit in the end and blank it off. That will do the job.
Same as D4/RRS.Breaker yard? 2012 TDV8 Vogue SE 4.4 |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 253 ![]() ![]() ![]() |
Well I found the actual part number for the cap LR013740 but even this alone is between £50-£60, WTF?
NOTSHARP Member Since: 04 May 2025 Location: Aberdeenshire Posts: 44 ![]() ![]() ![]() |
What is the OD of the pipe?
I think it is 8mm but I could be wrong. I am sure someone will be able to correct me if needed. |
