Home > Technical (L322) > 4.4TDv8 cap on oil extraction pipe
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My car has no cap on the pipe used for extracting the engine oil.Is this correct?The D4's I looked at all had a cap(cover)on the oil pipe.What has your 4.4 TDv8 got?Is it covered? 2012 TDV8 Vogue SE 4.4
Post #478084 11th May 2018 8:48pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Mine has one and I would of assume yours should too. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478086 11th May 2018 8:51pm
Should have a cap. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #478087 11th May 2018 8:53pm
Frans@Yamorna
Thumbs Up Thumbs Up What I thought!! 2012 TDV8 Vogue SE 4.4
Post #478088 11th May 2018 8:53pm
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Hi, I have the same problem.
Land Rover quote replacement of Scavenge pipe assembly LR043286 at £130.
Does anybody have a spare cap or know how to get one?
http://www.fullfatrr.com/gallery/albums/us...2211~0.jpg RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #540674 15th Jan 2020 3:40pm
Baltic Blue
Get a short piece of plastic tubing like in the picture in the last post, then find a suitable size bolt to fit in the end and blank it off. That will do the job.
Post #540678 15th Jan 2020 4:17pm
Frans@Yamorna
Same as D4/RRS.Breaker yard? 2012 TDV8 Vogue SE 4.4
Post #540679 15th Jan 2020 4:18pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Well I found the actual part number for the cap LR013740 but even this alone is between £50-£60, WTF?
I found that I broke one of the hook parts off my cap by being a little bit too vigorous getting it off. It still locks on securely enough and will be fine but I was just interested in the price of a replacement. After seeing that cost if it does eventually fail I will go with the tubing and bolt solution! Thumbs Up _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #718563 25th May 2025 3:17pm
NOTSHARP
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
What is the OD of the pipe?
Steve.
Post #718564 25th May 2025 3:26pm
ReggieMac
I think it is 8mm but I could be wrong. I am sure someone will be able to correct me if needed. Thumbs Up _______________________________________________
Post #718567 25th May 2025 4:26pm
