![]() | Home > Technical (L322) > Chargin the main battery while still connected |
| fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124
Duly ordered the 13 pin variant just now, £28.76
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Exactly how I top mine up.
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Doing that should not be a problem. As GAP says in its manual don't leave the IID connected as it does draw current. ISTR others on here do that without any problems. Cheers
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Richard,
Oh b****r, down in flames again |
I will also play with it again, but when the weather warms up a bit |
Mike
I will also check with my AVO, you can’t always trust these Chinese |
The IID manual states not to use the Ctek in charging mode as the supply is not clean and steady. The larger Cteks have a Supply mode which should be used with CCF edits. That’s the reason I bought the 10 version 👍
