Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs? |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
Hi all
3rd Jan 2020 6:06am |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
I haven't tried those but you can't fit any with a fan or heatsink on the back.
3rd Jan 2020 9:05am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Quote from listing:
3rd Jan 2020 10:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
I have some led bulbs with the rear rather bulky fans fitted to my secondary main beam headlights. Granted they are difficult to fit but not impossible, it means taking the headlight off the car to fit them. The light output is very impressive, had them on a couple of years now so probably due to fail soon. Would definitely fit similar again. |
3rd Jan 2020 12:31pm |
Did you modify the metal clip that holds the bulb in to the housing? |
10th Jan 2020 8:18pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Ive used the type with the aluminium webbed rope cooling strips on many different applications...
10th Jan 2020 8:25pm |
Have you got a link to anything, Craig?
10th Jan 2020 8:34pm |
Didn't need to modify it, but I did take it off and repositioned it, I think I moved it through 180 degrees from memory. As I said difficult to fit but not impossible. |
10th Jan 2020 10:28pm |
These are the type i have used... Not from this seller, but you get the idea sir... https://www.ebay.co.uk/itm/6B00-White-H7-6...SwQY9eFIqP |
11th Jan 2020 12:58am |
Thank you Craig.
11th Jan 2020 9:09am |
Often the plastic part of the LED bulb, the bit that takes the shape of the original bulb securing/locating ring turns 45/90 degrees and slides off! This allows you to fit the holder, then fit the bulb with a quarter/half turn to lock it in place sir... 👍 |
11th Jan 2020 9:43am |
Thanks for that Craig. Very thick of me not to notice that the plastic bit comes off. Still not sure they'll fit though. |
13th Jan 2020 9:05am |
Hi all
18th Jan 2020 11:31am |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Any body seen jim4244, said he was going to report back on these led bulbs hope they didnt fail on him and he missed that corner or the car broke down (other options are available). |
20th Jan 2020 1:56am |
