Home > Maintenance & Mods (L322) > Klunking noise in the engine bay upon cold startup in my 4.2
Page 1 of 3 123>
friskydog
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I have a klunking sound coming from my engine bay upon cold startup in my 2007 l322 4.2 supercharged. It's really concerning me. I am looking to upload a video for people to hear asap. Please if anyone can advise or has had similar issue I would appreciate any guidance. [/i] Range Rover Vogue SE 2007 L322 4.2 Supercharged 115k Miles
Post #541242 20th Jan 2020 11:53pm
friskydog
Ok am I being really stupid here but has anyone uploaded a video to this site as I seem incapable? Range Rover Vogue SE 2007 L322 4.2 Supercharged 115k Miles
Post #541245 21st Jan 2020 12:00am
Danwilderspin
Upload it to YouTube and post a link?
Is it an occasional clunk? If so it could be supercharger is looose (mine was luckily) or bearings in it. Easiest think is to take the belt off it of this is the car and start it up idling to see if it goes? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541354 22nd Jan 2020 12:10am
friskydog
Thanks Dan here is the link to the noise. I have just had my supercharger rebuilt by powerhouse. Have a listen see what you think.
Post #541363 22nd Jan 2020 7:19am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Mine sounds like a bit like that, it's got 227k miles on it so probably needs timing chains doing. I also think is has a slight misfire at idle on a cold start and I've read alot do that - Something to look into. As suggested above you should take off the supercharger belt then do a cold start and then take off the main aux belt and do the same. If the noise goes away that will tell you it's supercharger or ancilaries related rather than inside the engine.
Post #541369 22nd Jan 2020 10:18am
Danwilderspin
see this thread : https://www.fullfatrr.com/forum/topic53250.html
don't watch the first vid my mic wouldn't pic it up but the seconding sounds the same. You will see on mine the rear bolt when reinstalled cross threaded (and wasn't noticed) giving it about 5mm play. I took it all off thinking the charger was toast and before removing the charger I could rock it by hand making that noise. I recapped the thread and she purrs like a kitten now. If it isn't that its likely one one the bearings maybe even the one they can't replace as im pretty certain its a supercharger noise. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541374 22nd Jan 2020 10:52am
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
as dan said above,
also tensioners can make a similar noise, as said above quickly drop the belt off, see if the noise continues.
if it continues pray to the bank god!!!
if it stops then its a process of elimination.
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #541391 22nd Jan 2020 11:43am
friskydog
Guys cant thank you enough so far. I am having it all checked out atm so will update but really good responses thanks ever so much. Range Rover Vogue SE 2007 L322 4.2 Supercharged 115k Miles
Post #541410 22nd Jan 2020 2:10pm
MattHughes86
no worries,
i know things from experience
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #541420 22nd Jan 2020 2:59pm
Danwilderspin
No worries,
Anything down to removing the supercharger I can help with more than that is above my pay grade but Matt is going for it! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541431 22nd Jan 2020 4:38pm
stu1
To me it sounds more of a plastic/polyethylene clunk type sound.
Check that the fan isn't touching or hitting the shroud and that the shroud is correctly fitted. Also check the fan itself and all pipes in that area are correctly fitted. Also check the fan viscous coupling.
Post #541459 22nd Jan 2020 6:14pm
friskydog
Just to fuel this fire a little more it appears the noise goes away once the engine is warm. Go figure. Makes it even harder to solve. However all my tests have been whilst stationary.
Garage tomorrow are putting it on a car lift and removing under engine cover plates and trying to catch the noise before it disappears again.
I have sent the mechanic this forum link so he can review all your thoughts tonight. Thought it may help him out you lot seem pretty knowledgeable.
I will update this post as soon as the mechanic updates me. Smile Range Rover Vogue SE 2007 L322 4.2 Supercharged 115k Miles
Post #541665 23rd Jan 2020 10:27pm
kezbo1981
Let us know if they find anything. Going when warm suggests something warms up and gets back into tolerance, or oil gets somewhere and lubes it.
Post #541670 23rd Jan 2020 10:52pm
friskydog
Will do, also I have just had an oil and filter change and new oil filter housing seal. I use castrol magnatec fully synthetic 5w 30 A5. Range Rover Vogue SE 2007 L322 4.2 Supercharged 115k Miles
Post #541672 23rd Jan 2020 10:57pm
kezbo1981
Did it make the noise before the oil change?
Post #541673 23rd Jan 2020 11:07pm
Page 1 of 3 123>
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
