Home > Maintenance & Mods (L322) > Does the reverse cam turn on via relay
Danwilderspin
Hi all - trying to find a problem with my aftermarket stereo retrofit - with the original gear it worked now it doesn’t - looking at the wiring diagram it implies a relay is triggered to power it up but it’s very vague s is this the case and could I just feed this relay from a revere light ? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541527 22nd Jan 2020 11:54pm
but your stereo will only work when you go backwards ....... ... - .- -.
Post #541538 23rd Jan 2020 8:46am
Brian Considine
The camera power can be supplied directly from the reversing lights or via a relay (best practice)
AFAIK the original infotainment systems required a "negative trigger" in the boot which does require a relay.
These are the arrangements on my 2003 L322
Some aftermarket infotainment systems require a positive trigger & video feed at the head unit. 2003 Range Rover Vogue TD6
Post #541539 23rd Jan 2020 9:44am
Danwilderspin
Interesting as I have the 05+ unit I wonder if it’s still negative... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541808 25th Jan 2020 12:10am
AFAIK the camera is always on
There's a power trigger that causes the monitor to display it - and that's a very low current so wouldn't need a relay
That's how my other cars worked - I've not ventured into the exact mechanism in the RR but assume its the same
Post #541826 25th Jan 2020 8:40am
Brian Considine
The "BMW" cars need a negative trigger in the boot if using the original set up. 2003 Range Rover Vogue TD6
Post #541829 25th Jan 2020 9:50am
