![]() | Home > Maintenance & Mods (L322) > Does the reverse cam turn on via relay |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
but your stereo will only work when you go backwards ....... ... - .- -.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
The camera power can be supplied directly from the reversing lights or via a relay (best practice)
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2264 ![]() ![]() ![]() |
Interesting as I have the 05+ unit I wonder if it’s still negative... Current stable:
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8115 ![]() ![]() ![]() |
AFAIK the camera is always on
The "BMW" cars need a negative trigger in the boot if using the original set up. 2003 Range Rover Vogue TD6 |
