![]() | Home > Technical (L322) > Engine cut out & now won't start |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Youre going to have to give more information for anyone to help what size V8? does it crank? When you say from your garage have you just refuelled? correct fuel?
Joledger Member Since: 25 Jan 2020 Location: Trimingham Posts: 10 ![]() ![]() |
OK sorry. Its a 3.6 tdv8. I meant I had just had a service at my local car mechanic garage, where I think they changed the oil, oil filter, fuel filter and diesel filter, but need to double check.. I drove to my house which is around 5min drive and as I pull into my drive to slow turn the engine just konked out and now won't start but turns over? |
My first suspicion would be the fuel filter allowing air into the fuel system, if that's the case it will need bleeding etc. I'm not sure on the Range Rover try cycling the ignition on/off 5 or 6 times and see if that primes it with fuel, I may be wrong on this one but it wont hurt to try. I wouldn't keep cranking though, if the HP pump is dry it may do damage. BMW i3 Electric Car
Sorry I'm not very technical. So could it be the new fuel filter is faulty? Thanks |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 541 ![]() ![]() ![]() |
What AJG is saying is that when the fuel filter is changed it needs to be primed ie filled with fuel. There is a procedure to do this which involves turning on the ignition without starting the car. This way fuel should make its way to the filter and air should be expelled. Normal practice but if the garage hasn't done it or done it incorrectly it could cause a problem.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 566 ![]() ![]() ![]() |
I agree, sounds like a fuel issue. |
any developments? have you got it sorted? BMW i3 Electric Car
