Home > Technical (L405) > L405 Climate/Ac Heater issue. 2014 Model |
Jase71 Member Since: 13 Apr 2016 Location: Portsmouth Posts: 479 |
in the climate settings menu I think you can adjust the blower flow rate to be light, balanced or strong. That might help in the temperature sensor picking up the temperature? 2017 Range Rover Vogue V6 Diesel
29th Jan 2020 4:57pm |
dans1v Member Since: 29 Jan 2020 Location: Sheffield p Posts: 3 |
Hi there thanks for the reply.
29th Jan 2020 8:35pm |
James Brown RR Member Since: 26 Jul 2021 Location: Cheltenham Posts: 19 |
Hi Dans - I have the same issue in a 2013 L405 sdv8 Vogue SE - did you get to the bottom of it? I have to turn the temp up to 25 to start getting some heat through SDV8 Vogue SE
13th Oct 2021 5:46pm |
Hi a while since I asked the question but yes I did the car is long gone for a new one but if you remove the dash panel on the left of the steering wheel with the little ventilation looking grille in it maybe 25mm square there is a mini fan and sensor behind it. That senses cabin temp by sucking air from cabin over it. They either fail or get fluffed up, mine the latter clean off all the fluff and it spins free again. Without it running it finds it difficult to sense the temp and plays up. It’s a cheap part if it fails. Let me know if it’s this. |
13th Oct 2021 8:55pm |
Thanks Dans - I'll have a look and report back - great if its a cheap fix! SDV8 Vogue SE
14th Oct 2021 6:01pm |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 125 |
1st May 2023 1:09pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1071 |
How much has to be removed to access it and are there any hidden screws or clips. letters not necessarily in the right order |
1st May 2023 4:02pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
That panel with the grille is connected to the head unit surround, it's all one piece even though it looks like two bits, just get your fingers behind it and pull it straight off towards you... Pete
1st May 2023 5:31pm |
As above, it needs a good pull, start with the top glove box open.
1st May 2023 6:34pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1237 |
I’ve found that if you have the front and rear set at different temps then after a while they begin to fight each other. I set the temp to sync in the dash and just use the drivers one only to set the temp. V8 or else ... |
1st May 2023 9:20pm |
Thanks for the help. Inspected mine but not clogged, going to be harder to tell if it is working now the weather is improving.
2nd May 2023 7:27am |
2nd May 2023 9:04am |
If you pull the plug off it’s stops spinning so you can see it working. |
2nd May 2023 9:06am |
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 65 |
https://parts.jaguarlandroverclassic.com/l...ensor.html Not expensive but a lot of different part numbers for something that looks like the same part - One to go to the dealer for.
2nd May 2023 9:20am |
