![]() | Home > Technical (L322) > Wing Mirrors |
Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104 ![]() ![]() ![]() |
Hi the lights in my Wing Mirrors have stopped working have had them apart and changed the lamps but still no joy has anyone any ideas
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 ![]() ![]() ![]() |
Did you replace with normal 501 capless or go led ? |
Tried both and neither work |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 ![]() ![]() ![]() |
Are you able to move the mirror up, down etc with the toggle switch? Or the passenger mirror wont tilt downwards when reversing? what I had to do was, with the ignition off, pull the appropriate fuses, turn the ignition on for about 10 secs, turn it off, refit the fuses and turn on the ignition again. this resets it and it'll usually work again.. Hopefully the side lights are apart of this system and works for you. Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
Mirrors move as they should but will try pulling the fuses |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 ![]() ![]() ![]() |
May seem a silly quesion, but have you turned off the interior lights?
Put back in two good ordinary lamps did the fuses all interior lights working as they should but still no wing mirror lights are they only supposed to come on when you unlock using the fob ? |
They do on mine. I can't say on your model I'm afraid.
Got lights working don't ask me how and also work with canbus free led's |
