Home > Technical (L322) > turbo change
GGDR
Quite artisan / instagram those pics Ninio! Thumbs Up
. Cheers, Greg
Post #543456 9th Feb 2020 11:14am
steve57060
United Kingdom 2017 Range Rover Vogue SDV8 Loire Blue
Great pictures Nino.
Will check whether oil leak is from this area and report back. 2017 sdv8 4.4 vogue
2011 4.4 tdv8 (present)
2005 td6 vogue
2001 4.6 vogue (lpg conversion)
1999 2.5 diesel vogue (slowest car ever driven)
1996 4.6 vogue
Plus a couple of freelanders
Post #543532 10th Feb 2020 12:26am
steve57060
Been thinking about Turbo drain mod.
Does having the mod done just get round worn turbo seals?
Would changing turbo cure oil passover?
Have been quoted £300 for turbo rebuild which might get round problem.
views would be appreciated. 2017 sdv8 4.4 vogue
2005 td6 vogue
1996 4.6 vogue
Post #543771 13th Feb 2020 12:34am
GGDR
The drain reduces oil build up in the turbo. Hard to answer your question because it’s a bit chicken and egg I think.
excess oil could be the visible symptom in either fault. Ideally you might do both?
Interested to know about remove and replace because that turbo is buried, you can even see it even on a ramp from underneath..
Rob you suggested yours was replaced without too much taking Part...
. Cheers, Greg
Post #543810 13th Feb 2020 2:58pm
DrRob
Yes. Rovertune changed it quite easily. A job beyond me. Any more info, call them Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #543831 13th Feb 2020 7:36pm
