![]() | Home > Technical (L322) > Battery |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
even my 2004 L322 has a 950 Crank rating. 850 is tooo low! |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
It should be an 019 AGM Current: 2011 FFRR Vogue SE 4.4 TDV8
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
there are other threads about this issue.
Blueboy1 Member Since: 11 Oct 2016 Location: Cumbria Posts: 15 ![]() ![]() ![]() |
Thanks for your reply’s, as I thought it would be an agm battery,will see what he says tomorrow 👍 |
You may still have a drain.....
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Sorry breaking in to this thread which may help others . must have read this thread three times.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi, I bought a new AGM battery in June 2019, I have been having trouble with a suspension BONG after clearing faults with my IID tool I could sill not work it out?
Yeah new battery October from Halfords mine , so you still might have a drain somewhere if new one is letting you down . I will travel without my rear wiper for a while and see if my battery lasts better. I also changed the HEVAC Fsr without any difference.
Tubsie Member Since: 26 May 2020 Location: Essex Posts: 12 ![]() ![]() ![]() |
Having suffered the shame of the failed start (and the walk to the station) over the last couple of weeks and with the temperature dropping and only driving a mile or so to the station every morning which hasn't helped, so I've bit the bullet and bought this,
After my third go at chasing warranty , I came to conclusion that this Yuasa battery at 100a/h was not up to and after repeated reconditioning via the charger it has finally lost its capacity of power.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Just an observation. I've left my vehicle for over 3 weeks parked up whilst away at work and found no problem with starting. However, if working on car, which involves shutting and opening doors, the battery will die in fairly short order. I try to remember to connect up my ctek to prevent this but.....!
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
I have looked and looked in my owner's manual to find the Land Rover recommended battery specification and all I found was: - "REPLACEMENT BATTERIES Only fit a battery of the correct type and rating. Fitting an incorrect battery may result in a fire, or damage to the electrical system. If you are in any doubt when fitting a battery seek qualified assistance." Can anyone point me in the rigth direction to find the definative Land Rover recommened battery specifications? Many thanks. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD ![]() 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
