![]() | Home > Technical (L405) > New Engine 12 months ago now regular Limp mode up gradients |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
would the fuel tank level be the same when it goes into limp? ... - .- -.
| Richardince Member Since: 14 Oct 2018 Location: Suffolk Posts: 39
Not something I have noticed but would think doubtful Will note next time. |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
Does flooring it readily trigger the fault? |
No it needs to be a fairly high constant throttle held for 10-15seconds and always up a gradient, I have tried nailing it and this does not cause it to go into restricted performance. |
Best I can suggest is to try to have it fault on the way to servicing and don't switch it off until the fault codes can be retrieved. |
| charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174
Change the fuel filter, it fixed mine. Exactly the same symptoms |
Managed to get it to fail again on road where it has failed before and capture on video which I don’t think can post here?
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
Have you had the fault codes read? If not buy a GAP tool or have them read somewhere, without that information youre running round in the dark guessing BMW i3 Electric Car
Actually on 32 mile trip got to fail 4 times, a record! To get it to fail has to be hard acceleration after a stop at a junction. Stop then take off does it as well. Happy to buy tool to read code what of attached do I need? Or something else? |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Have you checked the fuel filter yet ?? Maybe to much water or crap in it. If it is a fuel filter issue, like water than the incline can cause that water to be pulled through with the fuel maybe. Not sure if there is a water drain on the filter that you can open and drain water out till the fuel starts coming through, maybe the likes of Craig can help you with that ???
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Buy the IID tool BT (blue tooth) for £399.
The car was at main dealer this week and they found a fault in the turbine shutoff valve which was replaced with the engine. Replaced under warrantee 👍 let’s home this has fixed it finally. |
| All times are GMT |
