Home > Technical (L405) > New Engine 12 months ago now regular Limp mode up gradients |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
would the fuel tank level be the same when it goes into limp? ... - .- -.
13th Feb 2020 9:57pm |
Richardince Member Since: 14 Oct 2018 Location: Suffolk Posts: 39 |
Not something I have noticed but would think doubtful Will note next time. |
13th Feb 2020 10:14pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
Does flooring it readily trigger the fault? |
13th Feb 2020 11:07pm |
No it needs to be a fairly high constant throttle held for 10-15seconds and always up a gradient, I have tried nailing it and this does not cause it to go into restricted performance. |
14th Feb 2020 7:55am |
Best I can suggest is to try to have it fault on the way to servicing and don't switch it off until the fault codes can be retrieved. |
14th Feb 2020 8:58am |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
Change the fuel filter, it fixed mine. Exactly the same symptoms |
14th Feb 2020 11:55am |
Managed to get it to fail again on road where it has failed before and capture on video which I don’t think can post here?
14th Feb 2020 5:43pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
Have you had the fault codes read? If not buy a GAP tool or have them read somewhere, without that information youre running round in the dark guessing BMW i3 Electric Car
14th Feb 2020 5:57pm |
Actually on 32 mile trip got to fail 4 times, a record! To get it to fail has to be hard acceleration after a stop at a junction. Stop then take off does it as well. Happy to buy tool to read code what of attached do I need? Or something else? |
14th Feb 2020 7:12pm |
Have you checked the fuel filter yet ?? Maybe to much water or crap in it. If it is a fuel filter issue, like water than the incline can cause that water to be pulled through with the fuel maybe. Not sure if there is a water drain on the filter that you can open and drain water out till the fuel starts coming through, maybe the likes of Craig can help you with that ???
15th Feb 2020 10:25am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
Buy the IID tool BT (blue tooth) for £399.
15th Feb 2020 5:28pm |
The car was at main dealer this week and they found a fault in the turbine shutoff valve which was replaced with the engine. Replaced under warrantee 👍 let’s home this has fixed it finally. |
29th Feb 2020 3:26pm |
