Home > Technical (L322) > Restricted Performance
Page 2 of 3 <123>
GGDR
I'd avoid driving it while you search for the leak, aside of short test drives if you are testing new hoses etc.
You may end up getting a red anyway, it doesn't take much from yellow to red.
In which case you could get your DPF guy to come back because they normally have a device that will clear the red.
The IID won't clear red.
But focus on the leak for now.
. Cheers, Greg
Post #544038 15th Feb 2020 9:53pm
DrRob
As Greg says, get it to a specialist LR independent for a high pressure smoke test.
In the first instance you could whip off the engine cover and have a look for soot around the inlet pipework....
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #544043 15th Feb 2020 10:28pm
jc132jc
Thanks guys, I will get onto this ASAP, with regard to the 4 hose did you use genuine LR upgraded hoses or just some inter cooler hose the correct size?
Post #544048 15th Feb 2020 11:49pm
I changed mine for blue sparco type silicone as the JLR ones seem to fail too often for my liking... Thumbs Up
Post #544052 16th Feb 2020 12:41am
DrRob
What Craig said Thumbs Up
Have a search on here but 70mm rings a bell. Check Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #544064 16th Feb 2020 9:13am
DrRob
Search function worked a treat Bow down
https://www.fullfatrr.com/forum/topic52120...p;start=15 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #544065 16th Feb 2020 9:18am
jc132jc
Thanks again guys, just ordered myself some silicon hose from fleebay, dose anyone have the part number for the intake, just in case it’s split. Lol
Post #544105 16th Feb 2020 4:58pm
Baltic Blue
Nine times out of ten it is just one of the original design hoses that have split.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #544108 16th Feb 2020 5:07pm
jc132jc
Hi Guys, quick update, so I have the air intake duct off today and as far as I can see all 4 donuts are fine, no splits or damage, although there was oily residue under 2 of them, not much but something has been leaking there.
Also noticed that the air intake duct outlet where the donuts go are look oval and not round ! I will post photos later to see what you all think.
Another thing is there is an oily residue under the inlet housing to the butterfly valve where the metal clip goes, looks like a common part to have a problem as they are everywhere online.
Post #544203 17th Feb 2020 3:42pm
jc132jc
Oily residue on the bottom of this, and the oval ports on the air intake duct .
Post #544205 17th Feb 2020 4:02pm
Baltic Blue
Part number is LR 092851.
https://rover.ebay.com/rover/0/0/0?mpre=ht...2916567335
£400 on eBay, but try asking Sophie for a price, just might be a bit cheaper with forum discount.
Post #544208 17th Feb 2020 4:20pm
jc132jc
Hi guys, just a quick update on my ongoing issue. After a lot of diagnostics and test runs, regens and so on I can confirm my problem is indeed a block DPF, but not with soot, hardened ash/rust deposits, so the honeycomb in the DPF is about 70 % blocked, as you can imagine it only takes a little soot to block it and cause problems, unless you continuously drive at 50mph.
So the great guys at my local garage are trying there best to clean/remove the ash/rust deposits, fingers crossed, but if they cannot then its a new DPF for me. OUCH Big Cry
I don't think there is anything I could have done to prevent this just an age related issue.
Post #546202 6th Mar 2020 3:37pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
fingers crossed for you they can unblock it.
Post #546204 6th Mar 2020 3:50pm
GGDR
jc132jc my suggestion would be to make sure the garage sends your DPF to get properly cleaned. Some clean 'out the back' with a pressure washer which is ok just but not really the proper way. Another cleaning technique is spray in foams and other solutions. Sometimes inserted via the sensor positions. Again ok but not the proper way to clean a DPF despite claims.
Trade places with the right kit such as a 'flash' machine clean DPFs for mechanics all the time. I had mine taken off and cleaned at a specialist with such a machine and they gave me a flow reading print out before and after. It's a big section of exhaust so the machines themselves are quite large to take a DPF without cutting it out too. Also worth checking.
Pls see my "What to do if your DPF is blocked" wiki for details including pics.
Main thing is to check they are sending it off to a proper place to be cleaned.
. Cheers, Greg
Post #546224 6th Mar 2020 6:02pm
jc132jc
Hi, so an update, sorry for the delay, my DPF is knackered as the garage could not remove the hardened ash/rust deposits.
They removed my old one, did 2, yes 2 cleaning cycles on their DPF cleaning machine, this removed a lot of rubbish but the hardened ash remained, so they then tried, carefully, to physically remove the it by hand by some sort of method but still no joy.
I managed to source a new DPF from Poland at a great price compared to LR and this arrived toady and is being fitted Monday.
I will post some photos of the old unit and how bad it is when I get it back.
Fingers crossed everything goes ok
Post #547006 13th Mar 2020 3:46pm
Page 2 of 3 <123>
