![]() | Home > Technical (L322) > instrument menu button |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349
It just doesn’t work / replicate on the dash , nothing. How do I get it to show even time , distance , mpg etc.
| dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529
it sounds as if either your dash is faulty or the button then buddy?
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
I think if you don’t have anything set to come up, it shows everything, though I appreciate ive not worded that the best..... by default, everything is shown.
So if you have the ignition on and press and hold the end of the stalk and nothing comes up on the centre display, I’d try disconnecting the battery for a few min to see if it resets. I’m stuck after that.
Thank you for your assistance , I have seen these pages in the book I will disconnect the battery and try again with setting steering immediately afterwards , I have seen the display more than a year ago but not now.
No change , I’m wandering I have inadvertently altered any CCF values. Trouble is they are not available to see on GapIID tool either ...... oh hell! |
Might need Navcoder, though I think the IID tool takes a backup the first time you plug it in, so the guys at Gap might be able to help? Might be worth asking them....
Had to refresh the Gap tool last night , now after plugging in it asks for ign on, not only on the mobile interface but on the car as well , so have been advised to check the diagnostic plug.
After a word with Gap support who have very helpful it looks like my ign barrel may be the culprit. Apparently a common problem with that age of L322. So maybe draining the battery if it’s faulty.
Moved on a bit here, tonight after pulling fuses for the diagnostic and instrument panel reset the Gap tool and saw the led change colour and bong the instrument panel lost the instruction to turn the ign on.
| All times are GMT |
