Home > Technical (L322) > instrument menu button
dazza1983
Im still confused as to what you want to do lol????
The system you have is the same as i had in my e46 m3 and my wifes e53 x5..
The button at the end of the indicator stalk does nothing that you would see on your main radio / navigation big screen...
The button will cycle through the information on the dash under your speedo and rev counter area etc..
What exactly are you trying to reset? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #544142 16th Feb 2020 9:01pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
It just doesn’t work / replicate on the dash , nothing. How do I get it to show even time , distance , mpg etc.
Sorry I appreciate your help here , it’s not important , I just wanted , which what started it , to see the time etc on the panel in front of me , and for some reason I can’t .
Post #544145 16th Feb 2020 10:04pm
dazza1983
it sounds as if either your dash is faulty or the button then buddy?
Have you a pic of you instument panel? Speedo/ rev counter etc Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #544160 17th Feb 2020 9:48am
mjdronfield
I think if you don’t have anything set to come up, it shows everything, though I appreciate ive not worded that the best..... by default, everything is shown.
I think you maybe use the centre screen to select what you want when cycling through on the instrument cluster, which is where the confusion with the centre screen has come in.
It’s been many years since I did this on my TD6 and I’m 50 on Wednesday so my memory isn’t that good Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #544164 17th Feb 2020 10:17am
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #544169 17th Feb 2020 10:31am
mjdronfield
So if you have the ignition on and press and hold the end of the stalk and nothing comes up on the centre display, I’d try disconnecting the battery for a few min to see if it resets. I’m stuck after that.
As you say, the fact you are running the later BMW firmware shouldn’t affect it, I had that in mine.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #544171 17th Feb 2020 10:35am
alfapat
Thank you for your assistance , I have seen these pages in the book I will disconnect the battery and try again with setting steering immediately afterwards , I have seen the display more than a year ago but not now.
That pic of the screen in the centre display headed Remote Control is missing on my menu in the central display , so that doesn't help.
Update soon.
Post #544189 17th Feb 2020 12:11pm
alfapat
No change , I’m wandering I have inadvertently altered any CCF values. Trouble is they are not available to see on GapIID tool either ...... oh hell!
Post #544254 17th Feb 2020 10:09pm
mjdronfield
Might need Navcoder, though I think the IID tool takes a backup the first time you plug it in, so the guys at Gap might be able to help? Might be worth asking them....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #544262 17th Feb 2020 11:07pm
alfapat
Had to refresh the Gap tool last night , now after plugging in it asks for ign on, not only on the mobile interface but on the car as well , so have been advised to check the diagnostic plug.
Will do tonight.
Post #544272 18th Feb 2020 8:23am
alfapat
After a word with Gap support who have very helpful it looks like my ign barrel may be the culprit. Apparently a common problem with that age of L322. So maybe draining the battery if it’s faulty.
I found the car dead yesterday with battery at 4v . It was running the night before!
What prompted them to make the decision was I asked them what one of the faults I keep getting , which has been there for 6 months now and never really bothered me . The fault says Auxillary sense incorrect. They replied it’s to do with the ign barrel .
A real barrel of fun ....Not !
ECUS, codes , keys etc.
Will try a clean of some sort , I expect a lot of crap gets in there .
Post #544414 19th Feb 2020 12:56pm
alfapat
Moved on a bit here, tonight after pulling fuses for the diagnostic and instrument panel reset the Gap tool and saw the led change colour and bong the instrument panel lost the instruction to turn the ign on.
Not worked out the instrument menu yet , but it’s progress!
Post #544506 19th Feb 2020 11:05pm
