Home > Technical (L405) > white smoke from exhaust on start up
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
I seem to be getting a lot of unburnt smelling diesel and white smoke from my car on cold start up. Disappears once the car is warm. Is this something normal or something abnormal I should get checked out while under warranty?
Thanks in advance Shocked 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #544572 20th Feb 2020 4:30pm
DrRob
I’d defo get it looked at for piece of mind
Doesn’t sound right to me Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #544588 20th Feb 2020 5:53pm
Vogue
A bit of white smoke on start up is normal - all mine have previously done this and it is merely condensation evaporating from a cold engine until it warms up.
A strong smell of diesel isn’t normal though, you do tend to get some fumes from the FBH though on a cold day on start up - especially if left to idle 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #544591 20th Feb 2020 6:17pm
is it from the exhaust of from under the car?
if its from under the car it could be the FBH as vogue says, it has a kind of kerosine burner smell.
otherwise if its from the back, then get it looked at. On a cold day a certain amount of steam from exhausts is normal. There is nothing that can't be fixed with a hammer😜😜
Post #544596 20th Feb 2020 6:37pm
Jase71
Thanks guys, definitely from exhaust pipes and so strong that it gets in to the cabin. I can only describe it as puffing white smoke...no changes in coolant or oil, 63k miles travelled. Service 1k miles ago. 2017 Range Rover Vogue V6 Diesel
Post #544601 20th Feb 2020 7:00pm
Jase71
http://www.fullfatrr.com/gallery/albums/us...ke%202.mov
http://www.fullfatrr.com/gallery/albums/us...ke%201.mov 2017 Range Rover Vogue V6 Diesel
Post #544666 21st Feb 2020 9:23am
Jase71
I was wondering if it was failing glow plugs but I'm guessing the rather sensitive ECU electronics would spot that one? 2017 Range Rover Vogue V6 Diesel
Post #544672 21st Feb 2020 10:03am
mines a 16MY tdv6 and i havnt used mine since yesterday morning..went out 5 mins ago,started it and no smoke like yours.
guessing yours is low on ad-blue maybe? ... - .- -.
Post #544678 21st Feb 2020 11:09am
Jase71
That’s an interesting point re: the adblue Stan.. might check that. What gave you that idea? 2017 Range Rover Vogue V6 Diesel
Post #544681 21st Feb 2020 11:40am
its only a theory ..the ad-blue is mixed with the exhaust gases and my thought is that if its low then he exhaust gases come out un-treated.. ... - .- -.
Post #544684 21st Feb 2020 11:50am
Jase71
I hope it is something as simple as that. I don't have any adblue top up warnings at the moment but I'll try topping it up anyway to see if it makes any difference. 2017 Range Rover Vogue V6 Diesel
Post #544686 21st Feb 2020 12:00pm
Bill
I thought the car will not start if low/out on ad blue. ....but what do I know? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #544775 22nd Feb 2020 11:06am
Jase71
I thought so too. Topped it up anyway and will see what happens.. 2017 Range Rover Vogue V6 Diesel
Post #544897 23rd Feb 2020 12:50pm
