![]() | Home > Technical (L405) > white smoke from exhaust on start up |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I’d defo get it looked at for piece of mind
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3820
A bit of white smoke on start up is normal - all mine have previously done this and it is merely condensation evaporating from a cold engine until it warms up.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8791
is it from the exhaust of from under the car?
| Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 494
Thanks guys, definitely from exhaust pipes and so strong that it gets in to the cabin. I can only describe it as puffing white smoke...no changes in coolant or oil, 63k miles travelled. Service 1k miles ago. 2017 Range Rover Vogue V6 Diesel
http://www.fullfatrr.com/gallery/albums/us...ke%202.mov
I was wondering if it was failing glow plugs but I'm guessing the rather sensitive ECU electronics would spot that one? 2017 Range Rover Vogue V6 Diesel
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35886
mines a 16MY tdv6 and i havnt used mine since yesterday morning..went out 5 mins ago,started it and no smoke like yours.
That’s an interesting point re: the adblue Stan.. might check that. What gave you that idea? 2017 Range Rover Vogue V6 Diesel
its only a theory ..the ad-blue is mixed with the exhaust gases and my thought is that if its low then he exhaust gases come out un-treated.. ... - .- -.
I hope it is something as simple as that. I don't have any adblue top up warnings at the moment but I'll try topping it up anyway to see if it makes any difference. 2017 Range Rover Vogue V6 Diesel
| Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279
I thought the car will not start if low/out on ad blue. ....but what do I know? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
I thought so too. Topped it up anyway and will see what happens.. 2017 Range Rover Vogue V6 Diesel
| All times are GMT |
