![]() | Home > Technical (L322) > P023d - 22 (6c) |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 ![]() ![]() ![]() |
Having now done a search and read all I can find, I have checked as best I can without dismantlling the plastic inlet manifold which seems clean and no evidence of soot, just a little oil at the back.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1858 ![]() ![]() |
Remove the lower intercooler hoses, and check for excessive oil... |
OK, will do, and if there is..... |
Hey Mikey, I hope you are around today.
I guess my real problem is finding someone with the knowledge and experience close enough to me in Valencia. The only option may be the local Main Dealer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
i used the forum search function and came up with these threads,
Small amounts of oil is perfectly acceptable. Sounds as though you have a boost leak, be it a top intercooler hose or cracked manifold A smoke test would highlight any issues ![]() |
Thanks Stan and Mikey, Stan I had found and read some of those threads, but there where a couple I had not. Thanks Mikey, I was beginning to doubt turbo after the no oil in hoses. So, more investigation needed. Can you briefly describe how a smoke test is performed please. |
https://m.facebook.com/story.php?story_fbi...9706667330
Thanks Mikey, clearly not something I can do myself, need to find a specialist now. |
