Home > Technical (L322) > P023d - 22 (6c)
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
P023d - 22 (6c)
Hi Guys,
Help with diagnosis needed. Last night driving home, felt a "thump" followed by no power and "engine system fault"
Had a look this morning, starts easily, idles smoothly, no load revs freely. Increase the load and it sounds clattery and no power followed by "esf".
Read the codes and only P023d - 22 (6c) showing ( what does the (22 6c) mean?
I recently replaced one of the top intercooler hoses (split) so removed and checked the other which was good.
So, what other causes are the of the code?
Any ideas?help gratefully received.
TIA David
Post #544786 22nd Feb 2020 12:54pm
DavidS
Having now done a search and read all I can find, I have checked as best I can without dismantlling the plastic inlet manifold which seems clean and no evidence of soot, just a little oil at the back.
No one ever mentions the clatter that I am hearing under load.
Post #544797 22nd Feb 2020 1:50pm
Mikey
Remove the lower intercooler hoses, and check for excessive oil...
Post #544801 22nd Feb 2020 2:41pm
DavidS
OK, will do, and if there is.....
Post #544803 22nd Feb 2020 2:52pm
Mikey
Big Cry Big Cry Big Cry
Post #544852 22nd Feb 2020 11:05pm
DavidS
Hey Mikey, I hope you are around today.
So, I have removed the lower end of both lower intercooler pipes, and a few drips from the right hand one and just a smear from the left.
I also seem to have lost a litre or so of coolant.
Any further ideas please.
Thanks, David
Post #544889 23rd Feb 2020 12:43pm
DavidS
I guess my real problem is finding someone with the knowledge and experience close enough to me in Valencia. The only option may be the local Main Dealer Shocked
Post #544890 23rd Feb 2020 12:45pm
i used the forum search function and came up with these threads,
https://www.fullfatrr.com/forum/search.php...rch_time=0 ... - .- -.
Post #544891 23rd Feb 2020 12:57pm
Mikey
Thanks, David
Small amounts of oil is perfectly acceptable.
Sounds as though you have a boost leak, be it a top intercooler hose or cracked manifold
A smoke test would highlight any issues Thumbs Up
Post #544899 23rd Feb 2020 2:16pm
DavidS
Thanks Stan and Mikey, Stan I had found and read some of those threads, but there where a couple I had not. Thanks Mikey, I was beginning to doubt turbo after the no oil in hoses. So, more investigation needed. Can you briefly describe how a smoke test is performed please.
Post #544900 23rd Feb 2020 2:21pm
Mikey
https://m.facebook.com/story.php?story_fbi...9706667330
A light oil is heated, and the inlet system gently pressurized, and pushes smoke out of any part of the inlet system that is not sealed Thumbs Up
Post #544909 23rd Feb 2020 4:42pm
DavidS
Thanks Mikey, clearly not something I can do myself, need to find a specialist now.
Post #544911 23rd Feb 2020 5:05pm
