![]() | Home > Technical (L322) > Electronic Park Brake release 2011 4.4 tdv8 |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
HELP !!!!
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
the emergency release is in the rear right hand cubby hole Mike...i think its a whiteish colour tab.. ... - .- -.
http://www.fullfatrr.com/gallery/albums/us...ation..pdf ... - .- -.
Cheers Stan.
I have pulled the emergency release, but car still refusing to move.
All fault codes clear, but this returns when I select reverse and try to drive....
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
What is telling you it’s was the handbrake? Cheers, Greg
Not without demolishing the house |
Greg,
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Dont drag it out. You.may cause more damage. Get it on some tyre dollies Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Cycle through low box and back Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks to a call from Greg,
Just been for a good run, manually paddled gears lots plus high and low ranges.
How many miles has yours done sir? Maybe the gearbox oil is getting old/moisture in? |
| All times are GMT |
